Polyurethane Steering Rack Bushings
Old 02-03-16, 04:59 PM
TRACKMKIII
TRACKMKIII's Avatar
Default Polyurethane Steering Rack Bushings
Hey guys its time for me to replace my steering rack and the bushings. So I am wondering where I can get polyurethane bushings. I see that Figs and Whiteline make bushings for the 2GS and SC so I was wondering if either of those will fit the 1GS?
Old 02-03-16, 08:30 PM
kene
kene's Avatar
I believe with the 1st gen gs300 the steering rack to frame mounting points are all metal w/ bolt and no rubber bushings. (Double check). 2 years ago I was planning to bolster the "steering feel" in the same fashion. But every steering rack image I found for the 1GS looked like it was not gonna happen.
To be honest, I am curious to see what else can be done in this area.
EDIT: I re-read your post. For some reason I thought you were referring to all bushings associated with the gs300/sc300 steering rack and column.
Old 02-04-16, 08:41 PM
kene
kene's Avatar
This PDF diagram may help you regarding the steering rack bushings. I don't believe there are any.
http://www.lexussouthatlantaparts.co...ey_model=15660
If improve steering is your Interest, rhe steering rack's damper shock (part# 45700) may be a start.
Another thing to look at for improved steering also is the steering shaft's "flex coupler" as seen in this CL link. It is the round black rubber piece that flexes/twists a bit when the steering wheel is turned.
https://www.clublexus.com/forums/sc4...0-shipped.html
Below is the gs300 1st gen PDF diagram of the steering column.
http://www.lexussouthatlantaparts.co...modelYear=1994
The flex coupler is found on part# 45260 in rthe diagram.
I have seen them replaced on other cars with a machined-metal copy, or a drilled out hockey puck. On rockauto.com the shaft is a straight metal shaft with no rubber coupler. So you can just buy it there.
Kinda long winded, but I hope this helps.
Old 02-07-16, 10:49 AM
Mandrake
Mandrake's Avatar
Another thing to check is your alignment settings.
dboo06is
12-19-18 05:39 AM
$C300
Suspension and Brakes
09-10-07 11:20 AM
jbw
13
08-12-07 10:14 PM
indypwr
33
04-17-05 04:02 PM
nuocmam122
02-22-04 02:23 AM
Quick Reply: Polyurethane Steering Rack Bushings
