1993 gs300 headlight issues
Old 07-16-14, 06:35 PM
Ogloc61
Ogloc61's Avatar
Default 1993 gs300 headlight issues
I have a 1994 GS300. When I turn on the headlights, The passenger side light goes dim and it seems as though both the low beam and high beam are turned on at the same time except they are only putting out about 20-30% power in each. The drivers side headlight works just fine. Also, when the high beams are applied, the passenger side goes out completely while once again, the drivers side works perfectly. I recently changed the bulbs to see if that was the problem but, it didn't help at all. Can someone please give me an explanation....Thanks
Old 07-16-14, 10:10 PM
ComponY
ComponY's Avatar
Try to make sure your brights are off first, and then test it.
What kind of bulbs are you using?
Does anything else in your car not work as well as they should be? Windows, radio and other electrical things..
Old 04-01-18, 04:59 PM
Robbie2j
Robbie2j's Avatar
I'm having almost the same issue with my g
93 gs300. The passenger headlight is dimmer than the driver side when the dim lights are on. When I flick the brights on the passenger side goes out completely. I have taken the bulbs out of the passenger side and put the. In the driver and they are fine.. could it be a bad ground maybe? They are the oem lights.
Robbie2j
04-01-18 05:09 PM
LexiLex
01-25-13 12:20 PM
usfstud27
12-06-07 09:36 PM
Quick Reply: 1993 gs300 headlight issues
