Trans Fluid
Old 06-24-14, 09:01 PM
Yarbird
Yarbird's Avatar
Default Trans Fluid
What transmission fluid should I use in my car? 94 lexus gs300 2jz-ge
Old 06-24-14, 09:30 PM
djspock303
djspock303's Avatar
Pretty sure its Toyota ATF - Type T-IV you can call the Toyota dealer to make sure or check with Auto Parts stores. Don't go to the Lexus Stealership though lol
Old 06-25-14, 07:27 AM
TRACKMKIII
TRACKMKIII's Avatar
Yeah the Toyota ATF type IV is the way to go.
Old 06-25-14, 05:17 PM
ClarkKent
ClarkKent's Avatar
I'm using Royal Purple... Expensive stuff but It's made me a believer.
Old 06-25-14, 06:20 PM
TRACKMKIII
TRACKMKIII's Avatar
Did you do a complete flush with the Royal Purple trans fluid or did you just drain and fill it? Did yoi notice any shift quality difference?
Old 06-26-14, 04:26 PM
Yarbird
Yarbird's Avatar
Hmm also question when I shift into drive there is a slight whine but it doesn't do it when I am in neutral. Only when sitting stationary... What could that be. Also when I go to shift from neutral to drive anyone else experience a jerking forward motion.
Old 06-26-14, 07:49 PM
djspock303
djspock303's Avatar
I would drain and fill it yourself first. It sounds like that is mostly your issue and its not going to harm your car. Mine Jerks a bit i think its just loud and clanky getting into gear, notice it more on an incline.
Old 06-27-14, 10:45 AM
Yarbird
Yarbird's Avatar
Royal Purple huh... Places like autozone should have it correct?>
Old 07-13-14, 04:14 AM
TxLexus400
TxLexus400's Avatar
i put toyota t-iv in my 93, when i first got it it was slow and sluggish. ive done 2 drain and refills within 3000 miles, fluid was pretty brown on the first drain, i have felt a dramatic change in the way it shifts and drives now.
Old 07-13-14, 02:24 PM
Nixspeed
Nixspeed's Avatar
I used redline fluid in every one of my cars. I did a full drain then a flush. My trans shifts firm and smooth. No whine or jerking.
Michael
13
11-24-13 08:59 PM
lexus114
09-20-13 12:46 PM
pjarvis
GX - 1st Gen (2004-2009)
10-15-10 04:09 PM
cvex
Maintenance
04-05-06 02:29 PM
Japanimal
07-24-03 07:22 PM
Quick Reply: Trans Fluid
