A/c compressor continuously runs even when turned off
Old 04-07-14, 06:00 PM
DJ8684
DJ8684's Avatar
Default A/c compressor continuously runs even when turned off
So my ac compressor is continuously running, even when I am not using it. What would cause this to happen? My ac blows cold and works fine, it's just that the compressor doesn't disengage when I shut it off from the panel inside. Where would I begin troubleshooting? Thanks in advance!
Old 04-07-14, 07:02 PM
TRACKMKIII
TRACKMKIII's Avatar
I had the same problem. It turned out to be a damaged leaking capacitor inside of the ECU. I sent it off to be repair and the problem was fixed.
Old 04-07-14, 07:25 PM
Nixspeed
Nixspeed's Avatar
Does it run even with the climate control all off? Ac will run in any defrost position.
Old 04-07-14, 07:32 PM
DJ8684
DJ8684's Avatar
Where did you send it off to get repaired? Also, how did you track it down to that being the issue vs a bad compressor?
Old 04-07-14, 07:33 PM
DJ8684
DJ8684's Avatar
Yeah, my climate control will be off and it will still run.
Old 04-08-14, 04:02 PM
TRACKMKIII
TRACKMKIII's Avatar
I checked for power down at the compressor and worked my way back until I realized that the ECU was constantly commanding the compressor to be on even when the switch was off. I sent the ECU to be repaired at lextech.org
Old 04-16-14, 04:58 PM
Luxor
Luxor's Avatar
Couldn't this be as simple as a sticking compressor clutch?
Old 04-17-14, 12:41 AM
Nixspeed
Nixspeed's Avatar
Not if its getting power to activate the clutch.
Old 04-17-14, 09:03 PM
PIONEER
PIONEER's Avatar
the fact that its blowing air when its off tells me something is screwy at the ECU/panel level. A sticky clutch you can check by hand when the car is off. It should be free and spinning when not engaged. If its stuck tot he pulley, it won't spin.
yamiken1
07-08-12 11:08 PM
chrisindub
Performance & Maintenance
35
07-08-12 03:35 PM
SC300-T
02-04-12 04:01 PM
818sc400
05-18-08 03:46 PM
racinstyle
06-17-06 02:07 PM
Quick Reply: A/c compressor continuously runs even when turned off
