Rack and Pinion: Pressure Return and Feed tube
Old 11-20-13, 07:27 PM
dal_lexus
dal_lexus's Avatar
Default Rack and Pinion: Pressure Return and Feed tube
Hi,
I have a 1995 Lexus GS 300 and I replacing my rack and pinion. I initially found the DIY instructions from this forum from D3AN. It was very helpful.
I goofed off by not writing the details when I removed the pressure feed tube and pressure return tube from the rack and pinion (please see the attached pictures). I have two banjo bolt - a brass banjo bolt and a metal banjo bolt, a double loop copper gasket and two metal washer (see attached jpg for bolt).
My question is - 1) which bolt goes to which hole on the rack and pinion?
2) which bolt matches with which gasket/washer?
I am afraid to mis-match the banjo bolt with the wrong gasket or washer. Thank you in advance for all the help.
Attached Thumbnails Rack and Pinion: Pressure Return and Feed tube-img_bolt_1.jpg   Rack and Pinion: Pressure Return and Feed tube-img_bolt_2.jpg   Rack and Pinion: Pressure Return and Feed tube-img_rackandpinion.jpg
Old 11-26-13, 12:43 PM
Felixmanx
Felixmanx's Avatar
Originally Posted by dal_lexus
Hi,
It looks like one bolt it bigger then the other... One washer is slightly larger too. I could be wrong,,,
Old 12-10-13, 08:08 AM
dal_lexus
dal_lexus's Avatar
Update: I am not mechanic but I was able to replace my rack & pinion, brake rotor, and upper control arms with the help of this forum DIYs and write ups. Thank you all for posting valuable information.
hippchip
11-25-16 10:46 AM
alain173
09-16-16 07:14 PM
Rudee023
05-24-11 01:23 PM
ICONYQ
Suspension and Brakes
02-03-09 01:01 PM
Herm
Maintenance
01-26-03 10:53 AM
Quick Reply: Rack and Pinion: Pressure Return and Feed tube
