2jz gte dies at 15 percent throttle but idles fine HELP!!
My car is a 96 gs300 with a stock 2jz gte with single turbo just put it in and turns over fine and everything and ideals but when i move the throttle to 15 percent it kills it self any had the same problem ??! HELP
Yeah it could be fuel pump/filter but if you have the 2jzgte map leave that in unless you are running a stand alone or piggyback ecu.
You'll need a bigger pump than stock anyway.
99SC42
Build Threads
08-02-14 03:56 PM
