Sputtering 1998 GS400, 218k Miles
12-02-11, 06:28 PM
Sputtering at idle at stop with foot on the brake. When I start to go, sputtering goes away. Got 'misfire' code and changed spark plugs. Sputtering still there.
Got 'P1349' code suggesting Oil Control Valve Filter is partially clogged. Filter Part number is 15678-46010.
Does anyone know how to replace this part?
12-05-11, 08:41 AM
No idea friend, but you should try to post in the second Gen GS forums for help on this issue....
12-05-11, 09:18 AM
yes, take everything apart until you get to it. Thats how I fix things.
12-05-11, 09:13 PM
Quote:
Originally Posted by
Stolen
Great idea, DONE
Thanx
12-05-11, 09:17 PM
It common on those OCV to get clogged. Try cleaning them out.
12-06-11, 02:26 PM
GS4_Fiend
Do you know how to get to the filter so it can be cleaned? What do you take apart?
12-07-11, 09:14 AM
re
the filter is located behind the timing belt assembly. So if you want to tackle this project the timing belt assembly need to be dissassembled.
volson
12-08-16 03:57 PM
jlawr
12-06-11 02:27 PM
02msmg3
12-13-10 11:47 AM
Falcon LS
12
10-11-09 07:45 AM
1998 ,
400 ,
change ,
control ,
diagram ,
gs ,
gs300 ,
gs400 ,
lexus ,
misfiring ,
motor ,
navigation ,
oil ,
p1349 ,
valve
