Is anyone using a fan clutch with the 2jzgte swap?
Old 06-17-11, 08:01 PM
supra247
supra247's Avatar
Default Is anyone using a fan clutch with the 2jzgte swap?
I have read every single thread and I have not got any answers. I need to know which combo to use, which radiator/shroud/fan blade?
I currently have a 2jzgte fan clutch with a 2jzgte oem radiator, a 2jzgte(96-98 supra part number 16711-46200) fan shroud and a 2jzgte fan flade.
Unfortunetly. The fan blade cut straigt threw the fan shroud and it shattered into pieces while doing a highway pull. I did trim the edges on the blade, but it still rubbed.
Is the answer a supra 93-95 turbo fan shroud(part number 16711-46160) or 93-98 Na fan shroud(part number 16711-46150)? I have read inconclusive answers on SF about the 96-98 supra fan shrouds being a slimmer profile.
I have read some people go with dual or single electric fans, but since Ive heard alot of complaints and Id like to avoid the wiring, I dont want to go that route.
Please, anyone who is currently or can verify the fan clutch setup, please leave a comment or pm me.
Old 06-18-11, 11:53 AM
jdmgs300
jdmgs300's Avatar
i HAVE A Gte swap with na clutch fan supra auto tt rad i have not install the fan shroud yet but i did have to trim the na clutch fan a bit to clear upper rad hose
Old 06-18-11, 04:33 PM
CHASER4LIF
CHASER4LIF's Avatar
Me and jdmgs300 are running the same setup.. I ran mine for 2 years now with no fan shroud and cooling temp needle stays in the middle even in 90 degree F,
Old 06-18-11, 07:17 PM
Kaiser
Kaiser's Avatar
The clutches are all the same. The supra fan blade is what the difference is. I also ran a griffin radiator with a stock gs fan shroud.
Old 06-18-11, 09:43 PM
supra247
supra247's Avatar
what do you mean the fan blade makes the difference? which one did you use?
Are you talking about the griffin radiator for the mkiv supra? If so, I have an oem mkiv rad and oem gs300 shroud and the bolt holes dont match up. In addition, I dont see it working properly considering there is a big gap in between the rad and shroud.
Old 06-18-11, 11:01 PM
Stolen
Stolen's Avatar
Another option you could probably do as a member on here has done is use the first gen IS300 fans, wcombined resivor. He's running a Na-T setup w no over heating issues. So no clutch fan, and no GS stock resovor. Looks really clean, some wiring needed to make fans work, and fabricated bracket to hold in place. And it comes on automatically. Just my 2cents.
Old 06-19-11, 07:50 AM
JamPatGS
JamPatGS's Avatar
I am almost finish with my swap and I used the stock gs radiator, shroud and fan with clutch.. I had to shim the mounting holes with washers and nuts to clear water neck, i purchased longer studs for it...seems fine haven't tested yet but pretty sure it will work.. anyone done this setup?
Old 06-19-11, 09:36 AM
Kaiser
Kaiser's Avatar
The Supra fan blade sits almost .5 closer to the motor.
GTX580
Performance & Maintenance
12-27-16 10:39 AM
phamxOC
SC400 / 300 Classifieds
06-09-14 09:36 AM
SC3Monster
06-07-13 05:23 AM
supra247
12-19-11 04:04 PM
Quick Reply: Is anyone using a fan clutch with the 2jzgte swap?
