The Official GS300 to Lexus Part Interchange thread
Old 11-09-14, 04:39 AM
  #91
93gsloko
93gsloko's Avatar
This assembly
Attached Thumbnails The Official GS300 to Lexus Part Interchange thread-shifter1.jpg
Old 11-09-14, 05:36 AM
  #92
TRACKMKIII
TRACKMKIII's Avatar
Originally Posted by 93gsloko
This assembly
I don't think its possible because of the extra shifter positions and the extra electronics involved but it would be very nice if we could!!
Old 11-09-14, 07:00 PM
  #93
onelt1
onelt1's Avatar
This assembly
So I searched to see if this fits cause I know I saw somebody with this already in their car and found that they DO NOT fit. The people that have these shifter's in their car have done extensive modifications to get it to fit. I say if you can do it, then do it, then create a write up so the rest of can do it. That would be the way I would do it if I could get a hold of a shifter for cheap.
Old 11-18-14, 01:58 PM
  #94
01gs3002jz
01gs3002jz's Avatar
Default 01 gs300 headers
I was wondering if supra mk4 engine parts fit my lexus gs300 v6 I believe its a 2jz, I wanted to put headers from a mk4 there less cheaper than the gs300 part and also was thinking of putting intake manifold from supra u guys know? Thanks
Old 11-24-14, 12:09 PM
  #95
onelt1
onelt1's Avatar
Search, that will be your friend for a while, till you get to know your car very well. I still search things on here and google, bing, yahoo, ebay, and many more. But to answer your question YES. It all fits the headers may be a bit difficult to get in, but they will. As for the intake, first thing is why would you want one? Second is it will fit, but you would need a new throttle, cruise and transmission shift cables. New or used throttle body. Relocation of your power steering reservoir. Your wiring harness will have to be extended in spots. There are probably more and perhaps someone will chime in, but again your best bet would be to search everything.
Old 11-27-14, 09:50 AM
  #96
vegaswins
vegaswins's Avatar
Hi,i recently swapped a gs300 tranny in my Lexus sc400,was told everything was plug and play,well after i got the tranny bolted in i found out,that was not true.Now im slapping my self in the face for not making sure it was 100% true.
So now im asking yall how i can fix this do not want to get a new tranny,now il explain my problems so after i figured out that the solenoid plug and whatever the thing is connected to the shifter shaft and the i believe to be speed sensor were all different plugs
so for the shifter shaft i swapped over the old one with no problems-solved
i swapped over the solenoid plug but the new tranny has 5,and the old one only had 4,so now no od
and the speedometer sensor has no plug at all on the new tranny,
so now my question is what can i do?
here is the closest pic i could find on the internet the small box looking solenoid is the one im missing the plug for
any help is very appreciated-sry for not being the best at explaining it all
btw the tranny does same the same model number as the old one
Old 12-20-14, 05:37 AM
  #97
Nanalexus
Nanalexus's Avatar
Default Lexus 94 gs300
Will 81 supra automatic transmission fit on Lexus 94 gs300?
Old 01-19-15, 02:27 PM
  #98
GS150x2
GS150x2's Avatar
Default 2000 Lexus RX interchangeable parts
What years & parts on a Lexus RX300 are interchangeable to a 2000 (2nd gen) Lexus Gs300.
Going to buy a steering wheel & shift **** from a RX300.
Much appreciated!
Old 01-26-15, 08:48 PM
  #99
aristoboyy
aristoboyy's Avatar
Does the sc300/400 rear wheel hubs fit on the 1st Gen Gs300 without any modifications ?
Old 01-29-15, 02:31 PM
  #100
forcefed44
forcefed44's Avatar
Will the Gen 2 front hub/knuckle assembly fit the Gen 1 without major modifications? I know people have said that the Gen 2 upper control arms fit Gen 1 GS. I have a chance to get newly bearing and hub knuckles from a friends Gen 2 since he totaled his..
Chris..
Old 02-02-15, 01:56 PM
  #101
GS150x2
GS150x2's Avatar
Default Interchangeable LEXUS RX PARTS
What parts from the LEXUS RX are interchangeable to the 2nd gen GS300 (98-05). Wood grain Steering wheel.
Old 02-02-15, 04:40 PM
  #102
forcefed44
forcefed44's Avatar
Chris..
Nevermind.. answered myself but trying it out.
Old 02-16-15, 07:36 AM
  #103
Unqlyrwstl
Unqlyrwstl's Avatar
Hello club I am wondering if 2nd Gen front coils fit on 1st Gen's? I know the rear will not work because of the fork mounting position the 1st Gen has. The front seems similar though. Anybody have any information on this? Thanks!
Old 02-26-15, 09:02 AM
  #104
vettefan
vettefan's Avatar
Default GS300 transmission
I need to replace the transmission in the 1999 GS300. I have found a transmission from a 1998 GS400. Will it swap in just fine? If not, why? Thanks!
Old 03-25-15, 03:19 PM
  #105
MyGS3
MyGS3's Avatar
Default Rear COntrol Arms
Do we know if the rear control arms from a 2GS will fit our cars? I need to replace the bushings but I'm thinking of replacing the control arm if the 2GS application fits.
The pricing for the control arm for our generation is outrageous!
Quick Reply: The Official GS300 to Lexus Part Interchange thread
