Clearing heads nd taillights
Old 03-03-11, 09:50 PM
aceboogie6
aceboogie6's Avatar
Default Clearing heads nd taillights
tomorrow im clearing my tail lights nd possibly headlights.does any1 have any tips for this job..i could use some..im not using the oven I just bought a heat gun..please tips or better instructions will help..ill post pics as I go along to
Old 03-10-11, 08:12 AM
Is300Tree2
Is300Tree2's Avatar
A guy on here took off the lines off his lenses but it took alot of sanding and some polishing. You should use a oven...heat gun will be slow as ****. Im sure your time is money...or at least mines is...Its not only a short cut but its the proper way. Your gonna have it come apart evenly with the oven.
Old 03-10-11, 04:15 PM
deknick
deknick's Avatar
using a heat gun is a pain in the ***, and putting them together with a heat gun only is a real PITA and rarely gets you a good seal. use an oven, it's your safeest bet
Old 03-11-11, 08:41 AM
aceboogie6
aceboogie6's Avatar
I did my tails no problem with a heat gun..it took about 15 min a light..but putting them back together was a lil hard..how long and wat degree should I put them in the oven
Old 03-11-11, 10:25 PM
clos
clos's Avatar
Set it to 200 and for about 20-30 minutes.
Old 03-12-11, 10:17 AM
deknick
deknick's Avatar
lowest setting possible, (may have to crack the door open a bit) and put it on a cookie sheet, but keep using new ones every 5 minutes or so, just so it doesn't get hot, you could also soak a block of wood and rest the headlight on top of that, keeping an eye on it to make sure it doesn't catch fire or burn.
there is no set time, depends on the oven and depends if you have to close the door all the way or not, lot of variances that can effect the time
Old 03-15-11, 04:40 PM
mkiiisupra
mkiiisupra's Avatar
when I did my headlights, I was using my moms brand new oven, at 300. I would keep opening the oven every couple minutes to check on it. I probably pulled it in and out of the over 5-6 times before it was soft enough to come apart.
Like Deknick said, too many variable from person to person. Use common sense and you're good...not too hot but warm enough to soften the glue, and keep checking on it over and over.
Old 03-16-11, 06:45 AM
jmax.garage
jmax.garage's Avatar
when you smell like something is burning, they should be done...
as in done DONE. D:
good luck!
flis250
04-03-16 04:34 AM
FuMoFFuTT
SC- 1st Gen (1992-2000)
23
03-23-10 04:50 PM
SloGS400
09-19-07 10:11 AM
go4dabukz
06-07-07 10:44 AM
STRONG SC
Lighting
05-02-06 10:54 AM
Quick Reply: Clearing heads nd taillights
