Interchangable Suspension Parts: Parts that work on our chassis.
#32
The Maker
Thanks for this thread. I will be looking into making arms for the Gen GS as well based on my other parts. If anyone wants to help by sending me worn out arms, it would accelerate devlopment.
Thanks,
Fig
Thanks,
Fig
__________________
Redefining Lexus Aftermarket Parts Since 2001
-- We are your Lexus suspension experts--
BCR - KW - PENSKE - OHLINS - HKS - GREDDY - STANCEPARTS
Links - Arms - SuperPro Poly Bushings - Solid Bearing Conversions - Motor Mounts
RB BBK's and 2P Rotors, G-Loc pads, Radium Fuel Systems
Custom Fabrication Design and Machining - Industrial 3D Printing - Laser Cutting
2018 USTCC Sportsman Class Champions - 2018 NASA ST5 National Champions
#37
heres something that hasnt been discussed! the rear UCAs from the same year range SC/ soarers has the same part number (48770) as the JZS147.
94 SC300 rear suspension diagram:
http://www.lexuspartsnow.com/Page_Pr...igPicture=True
96 GS300 rear suspension diagram:
http://www.lexuspartsnow.com/compone...8-04-1634.html
#40
looking at those two diagrams, the rear toe arms are the same # too
which would make these fit? no? If the IS300 is just a theory then these seem to be a solid, confirmed set-up. This may save headaches. I'm going to order them today, and if they fit, then i'll report back, but all seems to be good.
http://cgi.ebay.com/ebaymotors/MEGAN...#ht_2352wt_939
edit: i just DISSECTED the two diagrams. It looks like the rear toe arms, traction bars and even springs and struts are allll the same part number (which would lead me to believe the supra/sc300 rear suspension issues arise from the different lower control arms) the sway bars are the same, the sway bar links are the same, even 90% of the bolts and nuts are the same!
edit #2: Front lower control arm is the same part #, front sway bar, mounts and links is/are the same part number.
Also, in case anyone cares, even though it's not a suspension part, pretty much the entire exhaust is the same, including mufflers, which companies like megan make aftermarket versions of.
#41
I am pretty sure the sc toe arms are confirmed! I can order them when I get home! As for the IS parts, to my understanding the JZS147 shares suspension with the JZZ30 where the JZS161 had the suspension downgraded to the IS psrts in the rear! I know someone running IS RUCAs on a 161
What we need is a list of parts to play with! I can't find any RUCAs for the SC! Also I have read that the soarer RUCAs are physically the same and that only bushings, etc. And that's why the part number changes!
#43
Guys I went to a yard yesterday and i'm almost 60 percent sure that the upper control arm, spindle, and lower balljoint from a 1ls can fit in our 1GS's, but to confirm, ill pick these up someday during next.week just to confirm, don't know how useful that is
