will jzs147 suspension fit supra?
Why not get the model number of the certain suspension you are talking about, and typing it into google. You will defintly get some answers like that. I dont know if the suspension will work, because I'm pretty sure the MKIV stuff doesnt work on our cars. Not sure about the MVIII, never looked into it.
I just looked at the listing for Tein CS coilovers and it appears that the same part number is used between the MKIV Supra and 1st Gen GS300. I got the link to the Tein suspension line up from this forum in this thread: https://www.clublexus.com/forums/gs-1st-gen-1993-1997/56626-tein-coilover.html
Wanted to see if anyone could double check me on what I was seeing and if it helps any of us then all the better....
true, but the MKIV Supra only weighs a few hundred pounds more than the 1st gen GS300 so they shouldn't be that off....
*edit* After I posted that I came to the realization that if they are the same part number within Tein's catalog then I can't see why there would be a difference in spring rate. If there was a difference in spring rate then it would make sense that they would have made note of that by changing the part number.
Originally Posted by Caius
... If there was a difference in spring rate then it would make sense that they would have made note of that by changing the part number.
No big deal though if your not auto-xing or setting the car up for racing.
The numbers I quoted are for the Tein Flex's
SUPRA
JZA80-DST60-R1SS3
ARISTO
JZS147 -DST56-R1SS3
that is what i saw. it seems the part number is different. where did you see they were the same? i know the soarer/sc300 has the same part number as the supra.
JZA80-DST60-R1SS3
ARISTO
JZS147 -DST56-R1SS3
Originally Posted by fsr20det
do you know for sure that they will fit?
I have the 2nd gen gs3 flex's on my 1st gen gs3. The fronts were the same but the rears had to be modified and later I found out the lower arms are the same on the supra and GS as well as the upper pillow mounts. So thats how i know the MKIV supra rears will fit.
Alot of the parts are shared among the toyota lineup.
Originally Posted by EG8
True, true about the part number which is what stumps me. Last I looked the supras are around 783# and 448# where the sedans are closer to 559# and 504# .
Now I have the supra TEIN CS shocks for sell. JZA80-DST60-R1SS3. Whoever want them, email me. It will fit both Supra and Soarer. JZA80 and JZZ30 for sure.
Originally Posted by brianfung
No, I am just victim after reading these threads. I bought a set of TEIN CS stocks that was uninstalled from a Supra and tried to install them to my JZS147. Yes they can bolt in but the rear wheels camber are at about 12 degrees "declined out" and the fronts are at about 2 to 3. It is definitely not safe to run a car like this as the tires will wear out in a month or two. It is not doubt that these shocks are quite smooth and confortable. However, I have no choice but get a set of new TEIN SS for my JZS147.
