CA Accuair E-Level Management System
Up for sale is my Accuair E-Level management system.
It'll come with the following items:
-Touchpad
-(4) Sensors
-(4) Sensor Harness
-E-Level ECU
-Harness for the touch pad
-Main Harness for ECU
**For those who are curious, you can use this with any valving system. It does not have to use a VU4. I am currently using this system with the UAS Blowproof valves.
If you have any further questions please feel free to pm or text me.
DOES NOT come with:
-Tank pressure sensor
http://www.flickr.com/photos/44409312@N02/8476909358/
You can source a replacement one out from Accuair.
FULL DISCLOSURE:
- One of the sensor arms snapped due to incorrect mounting position from previous owner. The arm has been welded back together and works 100%. If you want to replace it, the sensor is $100 each. The sensor has been used for over a year on the fix with no problems to the E-Leveling system.
**Again the sensors are fully functional and the weld does not affect anything.
http://www.flickr.com/photos/44409312@N02/8493466812/http://www.flickr.com/photos/44409312@N02/8493467054/
-The ECU mounting tabs were all trimmed off. I have a slot built into my box to hold the ECU. You can 3m tape it to your box if need be.
The system is still on the car, will be taken off once I have at least a deposit.
Retails $1100
Further pictures can be provided to serious buyers, it's a pain in the *** to get to the ecu for my set-up.
Asking:
$800 shipped to ConUS
$775 picked up from San Diego (I am in OC at least once a month and can meet you there)
PM or Text 7One4 3Six9 Five383
-Touchpad
-(4) Sensors
-(4) Sensor Harness
-E-Level ECU
DOES NOT come with:
FULL DISCLOSURE:
Retails $1100
Asking:
To be specific... the sensor mentioned is still working and good. The leveling rod that attaches to the sensor is what is broken and being fixed. The rod is only $25 through OpenRoadTuning.com
http://openroadtuning.com/collection...vel-sensor-rod
canucklehe
04-27-13 12:38 PM
