FL ***VIAIR 380C 200psi AIR COMPRESSOR AIRRIDE Airbag Kit***
This is a used compressor that ive had for a few months. However i do not need it anymore so its now up for sale. Works fine and comes with mounting hardware! If you have any questions feel free to message me on here or you can call or txt 727 481 8370
Price is $120 shipped.
Viair 380C 200 PSI Compressor
Need high pressure? The 380C operates using low amp draw so it's versatile for many mobile pneumatic applications. Features include a standard 1/4” stainless steel braided leader hose with 1/4” NPT inline check valve and insulated wiring.
Viair 380C Features:
Oil-less Design
High Performance PTFE Piston Ring
Stainless Steel Valves
Moisture and Dust Resistant
Gearless Direct Drive Motor
Anodized Aluminum Alloy Cylinder
Automatic Reset Thermal Overload Protector
Stainless Steel Braided Leader Hose
Inline Check Valve
Remote Mountable Intake Filter Assembly
1 year manufacturer's warranty
Viair 380C Specifications:
12 volt
Permanent Magnetic Motor
Duty Cycle: 55% @ 200 PSI
Max. Working Pressure: 200 PSI
Amp Draw: 18 amps
Min. Ambient Temp: -40 degrees F
Max. Ambient Temp: 158 degrees F
Dimensions: 9" L x 4" W x 6.75" H
Net Weight: 9.75 lbs
Fill Rates
380C Fill Rates
2.5 Gallon Tank Fill Rate
0 To 145 PSI
3 Min. 30 Sec.
110 To 145 PSI
1 Min. 15 Sec.
0 To 200 PSI
6 Min. 05 Sec.
165 To 200 PSI
1 Min. 40 Sec.
5.0 Gallon Tank Fill Rate
0 To 145 PSI
7 Min. 20 Sec.
110 To 145 PSI
2 Min. 25 Sec.
0 To 200 PSI
13 Min. 25 Sec.
165 To 200 PSI
3 Min. 40 Sec.
380C Performance Data
PSI
CFM
A
BAR
LPM
A
0 1.34 12 0 38.0 12
10 1.27 13 1.0 35.5 14
20 1.22 14 2.0 33.0 15
30 1.17 15 3.0 30.5 16
40 1.09 16 4.0 29.0 17
50 1.06 17 5.0 27.0 17
60 1.02 17 6.0 25.5 18
70 0.97 17 7.0 24.0 18
80 0.92 18 8.0 22.5 18
90 0.88 18 9.0 21.0 18
100 0.85 18 10.0 19.5 18
110 0.81 18 11.0 18.0 18
120 0.78 18 12.0 16.5 17
130 0.74 18 13.0 15.0 17
140 0.71 18 14.0 13.5 16
150 0.67 18
160 0.64 18
170 0.60 17
180 0.57 17
190 0.53 17
200 0.49 16 *Supply Voltage: 13.8 Volts
Oil-less Design
Inline Check Valve
12 volt
Amp Draw: 18 amps
Fill Rates
380C Fill Rates
0 To 145 PSI
3 Min. 30 Sec.
110 To 145 PSI
1 Min. 15 Sec.
0 To 200 PSI
6 Min. 05 Sec.
165 To 200 PSI
1 Min. 40 Sec.
0 To 145 PSI
7 Min. 20 Sec.
110 To 145 PSI
2 Min. 25 Sec.
0 To 200 PSI
13 Min. 25 Sec.
165 To 200 PSI
3 Min. 40 Sec.
PSI
CFM
A
BAR
LPM
A
0 1.34 12 0 38.0 12
150 0.67 18
160 0.64 18
170 0.60 17
180 0.57 17
190 0.53 17
eyecon7
03-04-17 08:01 PM
