CA FS: ES300 Yellow Projector Fogs, 5mm Spacers, Amp, and misc....
Up for sale again and decided to make a new thread in here since the old one died out. For sale a pair of yellow projector fog lights off of a Lexus ES300. These can be used to retrofit into our fog lights there are some DIY's on this forum too. Come with just about everything besides the bracket. The projectors are good and the lens if you want to reuse them just need to be cleaned or polished. The bulb size are H3 just like ours but I don't know if they work as I've never hooked them up before. I'm selling these because I bought them to retrofit into my fogs but I haven't had the time to do it and I lost motivation after I let it sit for a while. Asking price is $OLD as that seems to be the going rate for these on forums which is better than ebay at $80+.
1of120's DIY
https://www.clublexus.com/forums/sc-...t-fog-hid.html
OEM Springs and rubber boots off of my 1997 SC400. Worked perfect nothing wrong asking $20obo.
OEM plastic fender liner strips. Came off of my 1997 SC400 nothing wrong perfect condition. $10
Universal 5mm spacers unused unmounted brand new. $OLD
Also for sale US Amps/RE Audio AMP XT800.2 V3 brand new never used only opened to look at. Asking $OLD.
Specs for Amp:
Features:
XT800.2 V3 400 watt RMS (800w peak) 2 channel bridgeable car amplifier
800 watts peak output
200w x 2 RMS @ 2 Ohms
400w x 1 RMS @ 4 ohms
100w x 2 RMS @ 4 ohms
Bridgeable
Efficiency: 70 % @ 4 Ohms or 65 % @ 2 Ohms
Fully adjustable butterworth high and low pass crossover filters
High pass filter - adjustable 40 HZ - 1 KHZ @ 12 dB per octave
Low Pass Crossover Filter - Adjustable 40 - 250 HZ @ 24 dB per octave
Adjustable Bass Equalizer: 30 dB Bass Boost @ 45 HZ
Subsonic Filter: 15-40 HZ @ 24 dB per octave
Low level Input
RCA Pre-amp output
Block Power Connector
Requires true 8 gauge power wire for installation
Screw terminal barrier strip speaker connectors
8 - 18 AWG speaker connector gauge
Aluminum heatsink
Convention cooling
power and protection LED Indicators
Class A/B
Frequency Response: 5 HZ - 50 KHZ
Weight: 7 pounds
Dimensions: 1.875" x 10" x 9.75"
I need to move these items because I have no room for them in my apt and now I am moving soon. Make me some offer guys worse I could say is no. I'm located in Chino area.
1of120's DIY
Specs for Amp:
Features:
Bridgeable
Low level Input
RCA Pre-amp output
Aluminum heatsink
Convention cooling
Class A/B
Weight: 7 pounds
