Sony DCR-DVD505 DVD Camcoder Bundle
Up for sale is a slightly used Sony DCR-DVD505 DVD Camcoder. This camcoder is top of the line in its set, it features a 4 megapixel integrated came, which can tape pictures while recording. It takes mini-dvd's which are 1.4 gigabytes in storage space and can hold up to 40 minutes of video, depending on the mode you select, in the highest resolution mode it will record only 20 minutes while in the medium resolution mode it will record 30 minutes. Well, here are the specs from the Sony (http://www.sonystyle.com/is-bin/INTE...=feature&var2=) site:
2.1 Megapixel (Gross) ClearVID™ CMOS Sensor
1/3" CLEARVID™ CMOS Sensor with 1910K (effective) pixels provides stunning detail and clarity with exceptional video (up to 530 lines of horizontal resolution) and still image performance. The Megapixel technology enhances your digital videos and digital still (3980K) photography performance.
3.5" Wide Touch Panel SwivelScreen™ LCD Display2 (211K Pixels)
The 3.5" Wide (16:9) LCD screen2 provides excellent viewing clarity with improved resolution. The high resolution 211K pixel LCD screen rotates up to 270 degrees for multiple viewing angles providing sharp, detailed images for monitoring or playback, and the widescreen format makes shooting in 16:9 mode and composing shots even easier.
Smooth Slow Recording
By increasing the record rate from 60 fields per second (fps) to 240 fps for 3 seconds allowing you to capture 3 seconds of fast motion and play the video back in 12 seconds. This is great for analyzing a golf swing or a viewing a bird in flight.
10X Optical/120X Digital Zoom
The optical zoom helps to bring the action close up from far away. In addition, the Digital Zoom interpolation means that extreme digital zooming is clearer, with less distortion than previous types of digital zooms.
Professional Quality Carl Zeiss® Vario-Sonnar® T* Lens
Carl Zeiss lenses have an advanced optical multi-layer coating that offers less glare and flare with increased contrast. This results in vivid image brilliance, true-to-life color saturation and perfect renditions of subtle tones. The additional T* coating on the lens further reduces unwanted glare and flare.
Active Interface Shoe
Provides a location directly on the camcorder to which to add optional accessories while providing power and two-way communication to those accessories.
Battery Information
At the touch of a button, battery information is displayed on the LCD screen when charging and when the camcorder is turned off. The display will show how much the battery is charged (approximately), in 10% increments and the recordable time left when using the LCD screen or in the viewfinder.
Digital Still Memory Mode with Memory Stick Duo™ Media130
Capture still images up to 2304x1728 resolution, directly onto Memory Stick Duo™ Media for easy transfer to PCs for emailing, printing or sharing with other compatible Memory Stick™ devices.
Dolby Digital 5.1ch Recording
The DCR-DVD505 will record in Dolby Digital 5.1ch surround sound with a built-in microphone. By recording in 5.1 channel surround sound you can now experience your home movies with active sounds coming from all directions. Enjoy your personal home movies the way you experienced them while recording.
DVDirect Compatibility
The DVDirect Multi-Function DVD recorder models MC3 and VC30 offer direct connection to the HDD Handycam via USB 2.0 and can record all the video on the hard drive to DVD or just what’s new and changed since the last DVD burn. What’s more, the video can be recorded from the HDD Handycam to DVD at up to 3X speed.
DVD Format Video Recording1
The DVD recording format delivers digital picture and sound quality comparable to that of MiniDV, but on DVD. Playback of the DVDs couldn’t be simpler. After finalizing the disc in the camcorder, the disc can play back in most DVD Players, computers and even PlayStation® 2 video game consoles.
DVD-R/RW and +RW Compatible4
The DCR-DVD505 is compatible with a variety of DVD formats allowing the easy of use and simplicity found in DVD Media. With DVD+RW media there is not a need to finalize the disc (minimum recording required). Simply remove the disc and insert the media into a compatible DVD Player3.
Easy Handycam Button
Using a camcorder can be intimidating for some people, so with a press of the Easy Handycam button, most of the advanced features of the camcorder are “locked out" leaving only the buttons essential for recording operational.
Manual Focus
Allows the user to manually adjust the focus of the camcorder using the touch panel. Manual focusing also allows the user to control the focus in difficult situations where either the environment or the subject does not allow the camcorder’s auto focus to perform optimally, such as when shooting through a window or in a crowded environment.
Super NightShot® Infrared System
With Sony’s NightShot Infrared System you can capture natural looking video, even when shooting in low light. Record subjects up to 20 feet away using the built-in infrared system.
On Screen Zoom and Record Buttons
For addition control of the camcorder, the DCR-DVD505 features Zoom and Record buttons on the frame of the LCD screen. This allows the user more flexibility when holding the camcorder, especially in overhead or low angle shots.
One Touch Wide Angle Shooting
Easily Switch between 4:3 and 16:9 aspect ratios for shooting, with just the touch of a button.
Picture Effects
Get creative when recording or playing back your videos with Sony’s Picture Effect Modes. Effects available in camera and playback modes: Sepia, Monotone, Pastel and Mosaic.
Picture Package™ Software
Easily organize still images/video content, and turn them into stunning music videos using the supplied software.
Program AE (Auto Exposure) Modes
Program AE modes make recording easy even when filming in challenging situations. Choose from Portrait, Beach & Ski, Sports Lesson, Landscape, Spotlight or Sunset & Moon modes.
Progressive Shutter System
A mechanical shutter system that provides progressive scan performance while utilizing an interlaced scanning system. Digital still images will be sharp and clear with excellent definition.
Su
Fader Effects
Enhance your personal videos by adding professional looking fader effects. Choose from Black, Overlap, White and Wipe.
InfoLithium® Battery with AccuPower™ Meter System6
Charge the battery at anytime because unlike NiCad (Nickel Cadmium) batteries, Sony’s rechargeable Lithium Ion batteries are not subjected to a life shortening “memory effect". Sony’s exclusive AccuPower™ meter 7 displays the approximate battery time remaining in minutes, in either the viewfinder or on the LCD screen.
USB 2.081 Interface
Provides an easy way to connect your DVD Handycam Camcorder to the computer for fast transfer of video and still images to your computer for editing. The camcorder can also be used as an external DVD burner, convenient for making copies of your DVDs or burning edited movies.
Specs:
Imaging Device: 1/3" ClearVID™ CMOS Sensor
Pixel Gross: 2100K
Recording Media: 8cm DVD (DVD-R/DVDRW/DVD+RW)
Recording and Playback Times: HQ: 20 min., SP: 30 min., LP 60 min.
Video Actual: 1990K Pixels
Still Actual: 3000K Pixels
USB Streaming: N/A
SteadyShot® Image Stabilization: Yes ( Super; Electronic)
Accessory Shoe: Active Interface Shoe
White Balance: Auto, Indoor, One-push, Outdoor
Memory Stick PRO™ Media Compatibility: Yes, Tested to support up to 2GB77 media capacity; does not support high speed transfer function; does not support Access Control security function.
Still Image Mode(s): JPEG
Minimum Illumination: 5 Lux (0 Lux with Super NightShot® Infrared System)
Low Light Capability: Super NightShot®
Analog Audio/Video Input(s): Yes (Multi A/V)
Analog Audio/Video Output(s): Yes (Multi A/V)
Digital Audio/Video Input(s): Yes (via USB)
Digital Audio/Video Output(s): Yes (via USB)
USB Port(s): Yes (2.0 compliant)
i.LINK® Interface: N/A
Component Video (Y/Pb/Pr) Output(s): N/A
Headphone Jack: N/A
Microphone Input: Yes (thru Active Interface Shoe)
Remote Jack: Yes (Mini Plug)
S-Video Input(s): Yes (optional accessory)
S-Video Output(s): Yes (optional accessory)
LCD: 3.5" (211K Pixels Wide 16:9 Touch Panel SwivelScreen™ LCD Display):
Lens Type: Carl Zeiss® Vario-Sonnar® T*
Viewfinder: Color (123K Pixels)
Docking Station: N/A
Microphone: Yes (Built-in 5.1 Channel)
35mm Equivalent: 42.8-495mm (16:9 Camera Mode), 45-450mm (4:3 Camera Mode), 40.6- 406mm (16:9 Memory Mode), 37-370mm (4:3 Memory Mode)
Aperture: f1.8-f2.9
Exposure: Touch Panel (24 steps)
Filter Diameter: 30mm
Focal Distance: 5.1-51mm
Focus: Full Range Auto, Manual (Touch Panel)
Progressive Shutter Mode: Yes
Shutter Speed: Auto, 1/4-1/4000 (AE Mode)
Optical Zoom: 10X
Digital Zoom: 120X
Power Consumption: 4.2W/4.6W (VF/LCD)
Battery Type: InfoLithium® with AccuPower™ Meter System (NP-FP60)
Power Requirements: 7.2V (battery pack); 8.4V (AC Adaptor)
Limited Warranty: 1 Year Parts; 90 Days Labor
Operating System Compatibility: Microsoft® Windows® 2000 Professional, XP Home, XP Professional
Supplied Software: Picture Package™ ver. 1.8, Nero Express 6
Video Recording System: DVD-Video/DVD-VR/DVD+RW Video
Video Signal System: NTSC color, EIA standards
Analog-to-Digital Converter: Yes (Signal Convert)
Weight: 1 lb. 6 oz (630g) with Disc and Battery
Measurements: 2 5/8" x 3 5/8" x 5 3/8" (76 x 92 x 149mm)
Heres pictures of the camera itself:
Along with the camera are included 2 batteries, 1 which is a standard sony battery which should last up to 60 minutes (depends which record mode is chosen) and the other one is an after market battery which will last up to 180 minutes (depending on the record mode chosen). Also 2 memory sticks are included, one is a 256mb memory stick pro duo and the other is a 2gb memory stick pro duo high speed, which should hold over 1000 pictures at 4 megapixel mode. Also included are 2 memory stick pro duo adapter to a regular memory stick size along with a usb adapter so that the files can be synced into a computer via usb.
The original camera box also comes with this bundle
Also included are various lens size adapters plus 3 filters
Also included in the package are 2 lenses, 1 is a wide angle (widescreen) lens which lets you see basically double on 1 screen (great for recording drag races at the track) and the other is a 2x zoom one, which basically has you zoomed without zooming.
Also included are various camera battery pack chargers
Battery Information
Manual Focus
Picture Effects
Su
Fader Effects
USB 2.081 Interface
Specs:
Pixel Gross: 2100K
USB Streaming: N/A
Headphone Jack: N/A
Aperture: f1.8-f2.9
Optical Zoom: 10X
Digital Zoom: 120X
And a spindle of mini-dvd's is included, which should provide hours upon hours of video (theres about 20 in the spindle)
Included are various adapter cables, power, usb, av etc... and a remote controller. Only the usb one was used once.
A lens cleaning kit is also included, which comes in very handy.
A carrying bag is also included which will carry all the equipment needed for the camera
Various booklets/cd's/certificates:
a up to 55 inch tall tripod in also included with a carrying bag:
So here's everything included with the bundle:
Asking prince is 1100$ O.B.O. , which is basically what the camera itself costs, not including all the extras. Thanks for looking. Pm or reply here if any questions or email itsme4g63@gmail.com :icon16:
Patsfan
09-08-05 02:12 PM
mcnelson
12-23-02 09:55 AM
