Tech support post your question here...
#64
The trouble that your going to go threw to change it from the cross over to the side intake would not be worth it. you would have to relocate your power steering pump and I'm not too sure if the computer even plugs up to the sensors. But for the trouble of getting a head and swapping it you might as well join the DARK SIDE.
#65
#67
guys got a problem my cigarette lighters doesn't work so i can't charge my phone or gps in my car i checked fuses and they are fine.Guess i'm gonna have to take off the dash to get to the lighter and check wiring but i can't find and visible screws or clips to take it off anyone got pics or can explain how to remove the center console bit?
#68
Very easy. If you are auto then you have to pull down the lower part of the shifter(plastic part). It's easier if you unlock the shifter first and put it in neutr. But it can be done in park. It will reveal 2 Phillips screws. Remove them and pull out the shifter. Then pull the plastic shifter bezel out and unplug the harnesses. It should snap out. Just be careful to use even force. It will reveal 6 screws. Then pull out the cupholder in front of the center console. It will reveal 2 more screws. Then you should be able to pull out the surrounding. And unplug harnesses. There should be a blue harness for the cig lighter.
I've done this process about 20 times already lol.
#70
I have TT MK4 wheels and stock lugs on my MK3 Supra. The thread pitch usually is the same between newer Toyota's. The depth of the stud is usually the issue. To make sure call a parts place or a wheel shop.
#71
Very easy. If you are auto then you have to pull down the lower part of the shifter(plastic part). It's easier if you unlock the shifter first and put it in neutr. But it can be done in park. It will reveal 2 Phillips screws. Remove them and pull out the shifter. Then pull the plastic shifter bezel out and unplug the harnesses. It should snap out. Just be careful to use even force. It will reveal 4 screws. Then pull out the cupholder in front of the center console. It will reveal 2 more screws. Then you should be able to pull out the surrounding. And unplug harnesses. There should be a blue harness for the cig lighter.
#73
ok i got one i am peiceing together my turbo kit but not ready to install it yet BUT i need to do some maintenance first on my GE. So my question is since I am going to change Timeing belt and water pump and front seals can I also install a thicker HG and run the stock engine without any problems for a while. Basically want to install the ARP studs and thicker HG and still be stock is thats ok or would I have to put on the HG and Studs when I do the turbo install
#74
