Tech support post your question here...
#436
93 Aristo swap
Hello from Michigan! Heres my I've noticed an exhaust leak between 2 pipes and since then I have no boost showing on my gauge and no power also. Then to top things off my accidently reset my Apexi SAFC back to 0s and now running real rich. I'm a disabeled vet and my family and I just moved here to Michigan and my ol'lady 2 kids and I are living off my VA and disability benefits so cash is tight right now. My question is is there anyway someone can help me with some numbers for the SAFC to get it somewhat close so it can be drivable. And any ideas on the lost boost no power issue. I'm gonna fix the exhast leak and do a boost leak test but could it be anything else. I did get into the throttle pretty last week and it ended up shutting down on me and wouldnt start back up till the next day thnats when the no boost no power was noticed and exhaust leak was noticable worse.Also when me buddy reset the SAFC. How or why is beyond me. I've been told a bad wastegate and a boost leak. PLEASE HELP. Heres pics and a list of what I'm working with. Garrett/Turbonetics T04E-60 Turbocharger Rated 300 to 550 current dyno is 425 whp High carbon cast steel turbo manifold 3 inch mandrel bent down pipe with closed loop Waste gate discharge Bead rolled inter-cooler piping Turbocharger intake system HKS external waste-gate Large front mount inter-cooler 28x6.5x3.5 HKS Racing bypass valve K&N STYLE air filter Oil Cooler Additional injector controller 440cc Lucas fuel injectors (2) Custom install along with 6 larger 3 Bar map sensor TDEAL 8.5.1 compression head gasket NOS 70 shot dry setup with 10 LB tank custom installed switches in armrest for power,remote bottle opener and bottle heater Magnecor spark plug wires BLITZ FATT (fully automatic turbo timer} custom installed in clock housing Boost controller Greddy Profec B Spec II Fuel Management controller
#437
P0330, P1135, and P1155
I have three error codes on my 2001 RX 300: P0330, P1135, and P1155. I know that this is the knock sensor 2 circuit, the air fuel sensor circuit, and the A/F heater circuit. Is it possible that there is an underlying problem that could cause all three codes to show up? I had to replace a catalytic converter, and my car locks out the overdrive intermittently. The mechanic wants to replace all of this stuff, at a cost of
#438
What these codes have in common is the wiring harness or the ECM could be the problem.
#439
Hello, looks like you've got a couple things going on there. For your 2001 RX300 these are actually common problems that I've seen through out the years. I'd say go ahead and have the A/F sensor replaced, its usually the bank 1 (firewall side) sensor 1 (pre cat). Knock sensors are pretty common as well, I'd clear the code and see if it comes right back if so time to change. For that job you should replace both knock sensors and the sub-harness connected to them. Let me know how it goes
#440
battery drain 2002 gs 300 sp. deisign ecu b1
Hi, any have this problem? battery drain 2002 gs 300 sp. deisign ecu b1 circuit. when ecu b1 fuse is pulled drain goes away. how do I isolate the problem. Thanks
#441
Is that the only fuse that will make the draw go away? If so then your gonna have get a schematic of that circuit and locate all the components powered by that fuse. BTW Any aftermarket parts installed if so start with those.
#443
#444
1999 es
I was driving the car on the highway when it started to bog down.
the engine light started flashing.
I limped it to my garage and there it sits.
any ideas.
any ideas.
BlueCrabby
RX - 1st Gen (1999-2003)
20
07-29-14 07:31 AM
