Hybrid Technology Unique topics related to the ES300h model hybrid drivetrain and other features/options found only on the ES300h. Please use the main 6ES forum for discussion about shared components with other sixth generation ES models.
What is your ES300h MPG?
Old 04-14-15, 08:23 PM
  #31
chromedome
chromedome's Avatar
I always get a kick out of gas station attendants pointing me to the RON97 pumps because they assume every big car needs premium. Most Euro cars here do, especially BMW turbos, but it's nice to be able to use the cheap stuff. One of my previous cars had a high-compression turbo that needed RON98 for full power, not much fun trying to run that thing. I wonder how much detuning has to be done to Euro imports if California gas is only 87 octane.
Old 04-14-15, 08:27 PM
  #32
Arty101
Arty101's Avatar
Not to forget ethenol that tends to eat up fuel systems, especially for older classic cars.
Old 04-15-15, 10:45 AM
  #33
PirelliRC
PirelliRC's Avatar
Originally Posted by chromedome
What's with all the speeding?
I thought the California speed limit was 65 mph. I'm surprised people are zipping around at 85-90... No fear of tickets?
It is 65, but you will **** a lot of people off if you drive the speed limit. CHP wont pull you over if you are going 75 mph unless you keep changing lanes and stick out like a sore thumb. As long as you keep your lane, you should be ok. Funny thing is, this is L.A. so a AMG 63 or M5 or an Aston Martin is a everyday sight, but those cars are not the ones driving 80-85mph, it is the people in Prius, Corollas, Subuaru BRZ and Civic Si that are driving like maniacs. I guess they have something to prove.
Old 04-16-15, 07:04 PM
  #34
wowzer
wowzer's Avatar
To wowzer, how did you get 49 mpg in city driving? I'm doing my best and I can only get 44 mpg. Hitting 50 mpg on a huge car like this would be awesome.
Pulse rapidly, then glide with battery, that is dont accelerate too slow or too fast. Just a tick into the white, then let your foot off the gas completely...this shuts down the engine. Then put your foot on the pedal to get the battery to glide you along. It takes some practice, but you can master it. I set my center display to show the engine, battery, and wheel so that i can easily avoid wasting gas. A lot of people get good mileage in sport mode because they accelerate quickly, then glide in battery mode. Avoid the brake as much as possible, drive on flat ground, and you can hit 50mpg.
When i travel on highway, my mpg drops. This recent tank, I'm at 43 mpg. I usually drive about 65mph...but i will pulse on the downhill and glide on the uphill...the cruise control does the exact opposite, so i dont recommend cruise control at all.
Btw, my tires get up to 37psi while driving on the highway.
Old 04-16-15, 07:09 PM
  #35
wowzer
wowzer's Avatar
I drive only in normal mode. I havent even tried sport or econ...
Old 04-16-15, 08:15 PM
  #36
chromedome
chromedome's Avatar
Thanks for the tips, I just refueled and I hope to hit 50 for this tank
I usually use Eco mode because it's easier to keep the engine off when moving off from a stop, at least up to 40 km/h. I've been accelerating within the top half of the Eco band, maybe that's too slow for high mpg. I guess it's like the race to sleep paradigm in mobile computing - accelerate hard and efficiently with ICE power to reach cruising speed, then coast or use minimal battery power to maintain speed. I don't like using pulse and glide in town because I can't focus on traffic.
I need to pump up my tires too. Mine are now 32 psi cold, 35 psi when hot, a bit too low I think.
Old 08-07-18, 12:01 AM
  #37
chester012
chester012's Avatar
Default The tank is getting smaller?
Originally Posted by wowzer
Just for disclosure...something weird about my numbers. My Odo shows 1397, but I've only filled up once. My MPG indicator showed between 39 and 40mpg, but I recall only filling up about 14 gallons this last time. The prior fill-up was about 16 gallons. Very odd...
The same thing is happening on my es 300h. My last fill-up was only 12 gallons? Do you know the reason? Thanks.
Old 08-07-18, 03:44 AM
  #38
Freds430
Freds430's Avatar
Received 1,052 Likes on 689 Posts
Had a 2013 ES300h and currently own a 2017. With both we get a combined 38 mpg which is about 30% highway and strict highway 40 mpg.
NdYAG
ES - 6th Gen (2013-2018)
12
07-06-18 06:33 PM
xHartawann
HS 250h Model (2010-2012)
48
05-07-10 02:22 AM
lx470man
IS F (2008-2014)
11-09-08 07:28 PM
Mike_TX
01-18-08 08:02 AM
mercy0171
08-26-06 03:45 PM
Quick Reply: What is your ES300h MPG?
