ES - 6th Gen (2013-2018) Discussion topics related to 2013+ ES models
Es 350 front side window- double pane?
Old 03-22-15, 06:56 PM
sharmila19
sharmila19's Avatar
Default Es 350 front side window- double pane?
I remember reading somewhere that tge front side windows are double pane- is that true? I just purchased one with a UL package and didn't find the double pane glass
Old 03-23-15, 05:13 AM
jollick
jollick's Avatar
My 2013 ES300h UL has double pane but my 2015 ES350 UL does not. Not sure why.
Old 03-23-15, 09:24 AM
sharmila19
sharmila19's Avatar
Then that's it.... Is probably only on 300h...
I called Lexus and they confirmed that 350 does not come with double pane glass
Old 03-23-15, 09:47 AM
Mike728
Mike728's Avatar
My 2013 350 has them.
Old 03-23-15, 12:25 PM
bc6152
bc6152's Avatar
Received 1,236 Likes on 868 Posts
How does one know? Is it printed on the glass? Also, I don't understand why the 300 would have it and the 350 wouldn't.
Old 03-23-15, 12:34 PM
lesz
lesz's Avatar
Received 1,010 Likes on 691 Posts
If you look at the glass edge and if you have double-paned glass, you can see 3 layers. Two of them are the two panes of glass, and the third is an air spacer between them.
Not only does it appear that some ES vehicles come with double-paned and glass and some have only 2 panes of glass, it also appears that there are different versions of the double-paned glass sourced from different manufacturers. On some of the double-paned windows, there is a small groove/channel on the edge of the glass between the two panes of glass. On others, all the two panes and the spacer panel between them are all on the same plane.
It also appears that some ES vehicles, regardless of whether they are Ultra Luxury, Luxury, or Premium package, have the double-paned glass, and some don't. My guess would be that the difference is based on Lexus getting its glass from multiple sources and on which of those sources was in use at the time of the vehicle build.
Old 03-23-15, 01:08 PM
LexBob2
LexBob2's Avatar
So I'm guessing if the different types of glass are due to using different suppliers, the performance is similar?
Old 03-23-15, 01:18 PM
jollick
jollick's Avatar
Here is what I have found.
My 2013 ES300h UL has double pane on the front only and the etching says Lamisafe. On the edge of the glass you can actually see the 2 pieces laminated together.
My 2015 ES350 UL has a thicker glass in the front than back but does not appear to be double laminated and the etching says Temperlite.
Old 03-23-15, 01:53 PM
bc6152
bc6152's Avatar
Ok, so I just went and looked at the front and rear windows. The front is clearly thicker, has a seam down the middle, and is labeled "Temperlite". The rear windows are thinner, no seam, and are labelled "Nippon Safety". 2013 ES350. So at this point I don't know if I have the double pane or not, but don't care as the car is quiet enough for me...
Old 03-23-15, 03:01 PM
Arty101
Arty101's Avatar
From what I can tell, my 300h doesn't have duel pane glass either.
Old 03-23-15, 03:36 PM
Kijug
Kijug's Avatar
The front two door windows in my 2014 ES UL has a "v" groove at the top...indicating two panes of glass.
Old 03-23-15, 03:51 PM
Arty101
Arty101's Avatar
No V groove or 3 layers on my 300h.
Old 03-23-15, 04:55 PM
don1
don1's Avatar
My 2014 ES300h also has this groove and the double pane.
Old 03-23-15, 05:17 PM
Mike728
Mike728's Avatar
I just went out and did a thorough evaluation. My 2013 has Lamisafe glass on the front windows, including the windshield. The Pano glass and rear window are Temperlite. The rear windows are labeled as Nippon Safety. Here's a couple pic's:
Front driver's glass:
Pano:
Old 03-23-15, 05:21 PM
jollick
jollick's Avatar
Yes, that photo definitely shows double pane glass.
Quick Reply: Es 350 front side window- double pane?
