Scuff marks of driver door threshold
I disagree, the directions that come with the door sills say you have to tap into an existing wire I think disagree (yes you could do this but there is an easier way ).
I will do a diy on this in the next few weeks but essentially you can "tap" into the fuse under the dashboard that turns the puddle lights on. No cutting or splicing necessary hardest part will be removing the trim and running wire (only the front illuminate) so not too difficult and you don't need to disassemble the dash. All of this is reversible and if you blow anything it would be the fuse which would be a cheap replacement (highly unlikely since they are LEDs ).
I purchased a pair of sewell for $200 and let me tell you they are worth it, really set the car off I get complements all the time.
TCKeyz
Automotive Care & Detailing
06-08-12 04:03 AM
