ES - 6th Gen (2013-2018) Discussion topics related to 2013+ ES models
View Poll Results: What type of gas are you putting in your car?
Regular
90.41%
Mid-Grade
2.74%
Premium
6.85%
Voters: 73. You may not vote on this poll
Old 10-23-12, 03:46 PM
Neoxagon
Neoxagon's Avatar
Default What type of gas are you putting in your car?
Do you have the hybrid or conventional gas model?
http://townhall-talk.edmunds.com/dir...38.f0d500d/145
Old 10-23-12, 04:27 PM
uicandrew
uicandrew's Avatar
well, technically, the engine is the same engine that's been in toyota camry/avalon/rav4/highlander for many years (at least 3+) with some exceptions.
the manual says that you can use unleaded. I plan doing 2 tanks of unleaded and then 1 tank of premium just to keep it "clean"
not necessary, but it's the thought that counts
Old 10-23-12, 04:31 PM
ElliotB
ElliotB's Avatar
"1 tank of premium just to keep it "clean" A quality regular grade fuel with detergent will do the job.
Old 10-23-12, 05:55 PM
Jim2003
Jim2003's Avatar
86K on my wives 2007 ES350. We have run regular its whole life. When I do the oil change I put a bottle of Chevron Tettron in the tank. My wife gets 24 to 26 mpg in town. We get 29 to 31 on the highway with me driving. No reason to run premium gas.
Old 10-23-12, 06:01 PM
Dave Mac
Dave Mac's Avatar
I am most certainly not an engineer but I don't think premium unleaded is "cleaner" than regular unleaded gasoline.
I have often put premium in the tank looking for better performance but truly can not see either a performance or mileage difference.
I do occasionally put a can of Techron in the tank but again don't see any effect.
Dave Mac
Old 10-23-12, 06:46 PM
simwilson
simwilson's Avatar
Default gas for lexus es 300 h
Yes, the recommendation is regular gasoline only. I have read about the aktinson engine which is the engine used in this model as well as the toyota camry hybrid. With going into alot of technical detail. This engine was made to handle the lower octane fuel. i even read where some thought that e85 could also work. i would not attempt doe to this not being recommended by the manufacturer. i suggest reading about the atkinson engine. It's very informative.
Old 10-23-12, 07:48 PM
MY100thcar
MY100thcar's Avatar
I have not read about the aktinson engine but I would like to.
Can you post a link to the info.?
Thanks, Joe
Old 10-23-12, 08:45 PM
flowrider
flowrider's Avatar
Received 1,831 Likes on 1,293 Posts
Dave Mac
You are in fact correct. The detergent content is the same for all three grades.
Lou
Old 10-23-12, 08:55 PM
xspsi6
xspsi6's Avatar
Premium fuel burns slower thus is actually a more dirty burn unless you have the proper cyl pressure to use the high octane fuel to it's full or close to it's upper potential so in actually it does the exact opposite as you may think.
In other words anything other than regular is a waste and may be harmful in the long run.
Old 10-24-12, 02:19 AM
UncleBen
UncleBen's Avatar
Wow! That's news to me. This thread and your post caused me to Google the subject and came across this article.
http://usatoday30.usatoday.com/money...E=click-refer&
I was one of the ones using Premium because I thought it kept the engine cleaner and because of its anti-knock properties. Back to regular! Thank you!
Old 10-24-12, 07:46 AM
xspsi6
xspsi6's Avatar
That is a good read^^ and almost everyone should read this as it goes in depth on the subject.
Old 10-24-12, 12:23 PM
UncleBen
UncleBen's Avatar
Yeah ... Moderator(s) ... is this a good candidate for a sticky?
Old 10-30-12, 07:22 PM
Neoxagon
Neoxagon's Avatar
+1, very informative article!
Old 10-31-12, 11:07 AM
Neoxagon
Neoxagon's Avatar
Found another great article:
http://www.caranddriver.com/features/regular-or-premium
Interesting..
"High altitude reduces the demand for octane."
Old 06-27-14, 11:36 AM
Newtype
Newtype's Avatar
Default ES 350 owners, what gas do you use?
It's still shocking to me that the ES 350 does not require premium gas. My state's gas station sells 87, 89 and 92 what would you guys recommend I use? Would it hurt the car even if I put premium in there?
Quick Reply: What type of gas are you putting in your car?
