BASS! Rockford Forstgate P300-12
I added a lot of Bass to my ES by installing a P 300–12 Rockford Forsgate powered sub. This woofer really hits hard and rocks the car while filling it with bass. The installation of this unit is not quite a D I Y type of job. You have to connect this power subwoofer as you would connect an amplifier by running wires to the battery and grounding the woofer to the car. But you can use speaker level inputs and not patch cords.
It comes with a wired remote so that you can control the amount of bass. I mounted it on the side of my seat with Velcro. So far I haven't turn the volume of the bass past halfway. My wife on the other hand keeps it at almost off.
The cost was $184 From eBay. http://m.ebay.com/itm/351069267295?nav=SEARCH
I tapped the factory sub for one side and the driver side rear door speaker wires at the b pillar for the other input. That is the part that may have you looking for the local audio store. Hey you can do it, I did. Oh, you will need an amp kit if you are going to take this on.
You need two inputs. Like right and left. There is only a sub on the back deck of the base audio system ES. So no other place to go but the rear doors. Here is a shot of the wires.
Lowrider25
04-30-18 07:54 AM
handzilla
07-11-06 06:08 AM
