ES - 6th Gen (2013-2018) Discussion topics related to 2013+ ES models
What do you use to clean dash/side panels?
Old 04-20-14, 09:05 AM
4x4tx
4x4tx's Avatar
Default What do you use to clean dash/side panels?
My wife used some armor all wipes with left streaks on the dash and doors..what is the best thing to use?
Old 04-20-14, 09:09 AM
LexBob2
LexBob2's Avatar
Meguiar's Ultimate Quick Detailer works well. Low luster shine, not much fragrance and easy to use. available in spray or wipes.
There are A LOT of products out there that work well too.
Old 04-20-14, 10:12 AM
lesz
lesz's Avatar
Received 1,010 Likes on 691 Posts
I would stay away from Armor All products. While it is only anecdotal evidence, if you read threads about cracked dashboards and other problems, you will find a strong correlation between those who have had the problems and those who have used Armor All. While feelings aren't unanimous, there are many who believe that the ingredients in Armor All products will, in the long term, dry out the surfaces that are treated with those products. Further, I would stay away from any product that lists silicone, either as a product component or as a carrier for other ingredients.
Over the years, I've also become a fan of Meguiar's products for both interior and exterior maintenance. That said, for most cleanup of dashboards, armrests, etc., I've found that wiping then with a soft, slightly dampened cloth is sufficient.
Old 04-20-14, 03:19 PM
mikeys350
mikeys350's Avatar
I use this for plastic and on my tires
http://www.chemicalguys.com/Chemical_Guys_TVD_103_Blue_Guard_II_p/tvd_103.htm
Old 04-20-14, 05:13 PM
Received 2,520 Likes on 1,818 Posts
I'll second this. For quick interior cleanings its hard to beat this.
If you've got armor all streaks you need to remove, I would use this product to start:
http://www.autogeek.net/ultima-interior-shampoo.html
That is also great for leather and removing dye transfer from light colored seats.
Old 04-20-14, 06:35 PM
jbm79
jbm79's Avatar
I understand the hate on the old Armor All that leaves a glossy finish. But how about the Armor All Natural Finish protectant? How is this a bad product?
Old 04-20-14, 06:37 PM
Its not. Even the "original" Armor All is not a "bad" product. Personally, I don't like *any* protectant on the dash because I like a matte OEM looking dash, but these products won't hurt your dash
Old 04-21-14, 06:04 AM
Max707
Max707's Avatar
Based on a lot of reading and research I buy 303 aero. High UV protection, protects from cracking not high gloss, no streaking and "Most" important water based. Read the "Detail" section of this forum 303 Aero is the most recommended. You can get it on Amazon, couple of years supply for around $17. Also use it on the Nuluxe seats or the coated Lexus leather seats.
Old 04-21-14, 07:57 AM
Canesguy
Canesguy's Avatar
Griot's Garage interior cleaner for removing grease and dirt without harmful chemicals, strong scents:
http://www.griotsgarage.com/product/...ortby=ourPicks
Old 04-21-14, 11:46 AM
303 Aero is a great product, IMHO its too glossy for dashboards.
Old 04-21-14, 02:16 PM
lamikela1
lamikela1's Avatar
I personally have used Armor All products for years on a variety of cars including my 2008 and 2013 Lexus and have never experienced any dash cracking or negative effects from it, including streaks or runs. I would not go as far as saying that it's a bad product. But having said that I have tried Meguiars and it works at least as well or better than Armor All. I think it's mostly preference, climate, ultraviolet exposure, and level of care that makes a difference. Not so much what you use or don't use. Just my 2 cents...
Old 04-21-14, 02:36 PM
CodemanGS
CodemanGS's Avatar
I have been a GRIOT'S GARAGE Fan, for twelve years. They have a great deal of SUPERIOR Products. Some of their wax and cleaners will take a bit of learning how to use, but the finish is quite superior. If you follow their instructions, you will be very pleased. And the Interior Cleaner, works wonders. It will easily clean just about any stain you have. The 'trick' with this cleaner, is what type of brush you use. And, it is delivered to your door. Check them out:
Old 04-21-14, 02:55 PM
Max707
Max707's Avatar
Just make sure whatever product you get is water based. If not in the long run it can damage your vinyl/plastic surfaces. Lexus seats are coated so leather care products are not recommended since it is coated leather. If you read the ingredients on some of these well known products they are not compatible with vinyl/plastic but people think they are doing the right thing.
ryca
RX - 3rd Gen (2010-2015)
03-03-12 06:54 PM
LexPaul
Automotive Care & Detailing
29
08-31-09 10:53 AM
Collins
07-19-07 09:35 PM
your momma
10-04-06 12:40 AM
Quick Reply: What do you use to clean dash/side panels?
