ES - 6th Gen (2013-2018) Discussion topics related to 2013+ ES models
Low audio level on CD's with ML system
Old 12-29-13, 08:12 PM
tmotto
tmotto's Avatar
Default Low audio level on CD's with ML system
Has anyone experienced audio levels significantly lower while playing CDs versus the radio?
The audio system sounds great except for that. I have to set the volume to 59 to get reasonable levels vs. 38 or 39 on the radio.
Old 12-30-13, 02:55 AM
ElliotB
ElliotB's Avatar
Yes, I have the same issue. And the problem got worse with the new amp. I have a LS and the audio system has the same issue.
Old 12-30-13, 07:32 AM
atoyota
atoyota's Avatar
I found it helped if I increased the treble and midrage.
Old 12-30-13, 08:13 PM
jollick
jollick's Avatar
After reading your post I tried it on my 2013 with the new ML Amp. I switched between the FM radio, a CD and a USB mp3 drive. On my system they were all at about the same volume level. In fact the radio seemed just slightly lower in volume than the other sources. Is you CD a store bought CD or home burnt? If a it is not a store bought it may be the software that created it causing the lower volume. Just a thought.
Old 02-21-14, 03:27 PM
mcomer
mcomer's Avatar
atoyota brings up a good point, the tone settings can be set descretely for each source.
See if you have not jacked up the levels for the tuner, they would not have affected the CD.
Old 02-21-14, 04:25 PM
Arty101
Arty101's Avatar
Not only the tone settings, but I think the volume setting is set for each source.
radcoupe
RC - 1st Gen (2015-present)
24
09-25-20 12:58 PM
dbs600
04-13-14 05:47 PM
jlarami
ES - 5th Gen (2007-2012)
11-29-08 06:15 PM
Quick Reply: Low audio level on CD's with ML system
