Deleting Presets
Deleting Presets
Can you please let me know if there is a way to delete presets (not overwrite). Also can you delete any of the pages. For example there are 6 pages but I only want to use 3?
Also can you delete the tab labeled "SAT" as one of the choices.
You can program any of the presets with station choice you want, you are not limited by the tab heading. So for example you can have an FM station right next to an AM station and right next to a XM station in the same tab.
I don't believe you can delete tabs. Not sure if you can delete presets without overwriting them.
Tabs for USB/Aux/CD are greyed if not connected. Since even an expired Sat account is still broadcasting the Channel 001 propaganda the car will leave the tab on.
The new gen audio in the IS allows you to customize the number of presets but our ES doesn't. Try setting your stations in a repeating pattern, ie., if you have 9 favorites then enter them in order 4 times. Where ever you are on the ladder of presets you can use the steering wheel rocker to move up and down. Note that on the Nav level cars you can use the console zooming rocker switch to move the preset quadrants quickly.
