Tire Pressure on 300h for best gas mileage?
Old 02-01-13, 06:11 AM
brunla
brunla's Avatar
Default Tire Pressure on 300h for best gas mileage?
I have the standard 17" tires. What is the suggestion for best tire pressure for gas mileage?
Cold and warm numbers.
Thanks.
Old 02-01-13, 06:45 AM
IS350atWOT
IS350atWOT's Avatar
It really depends on how bumpy you can take it. Put as much as you can in at the cold rate without going over the max pressure that is stamped on the tire and without making it too bumpy of a ride for your taste. What is on the sticker inside the door jamb will give the most comfort. Obviously, the max pressure will make it very bumpy. I started with mine at 40 lbs. It was too bumpy. So I backed it back down to 35. It's a lot better, but I haven't checked the gas mileage yet. I won't go below 33 which is what the door jamb has.
Old 02-01-13, 08:09 AM
ElliotB
ElliotB's Avatar
"What is the suggestion for best tire pressure for gas mileage?"
The maximum rated pressure - the cold pressure rating should be listed on the side of the tire. Rolling resistance is reduced at higher pressures. But the ride will be a bit firmer (which I like).
Stu
10-12-10 06:27 AM
kevs
Wheels, Tires & Brakes Forum
09-28-07 10:43 AM
looknow12
GX - 1st Gen (2004-2009)
13
03-08-03 02:18 PM
Quick Reply: Tire Pressure on 300h for best gas mileage?
