Hybrid Technology Unique topics related to the ES300h model hybrid drivetrain and other features/options found only on the ES300h. Please use the main 6ES forum for discussion about shared components with other sixth generation ES models.
Just got a 2017 es300h what next?
Old 10-16-21, 11:00 PM
Maxitor
Maxitor's Avatar
Default Just got a 2017 es300h what next?
Just got a 2016 es300h at 95k km and was wondering what should I do next? I’m thinking I do cabin air filter and engine air filter. What next though? Should I buy some PEA fuel additive any other things I need to worry about? And do es350 carpets fit the 300h?
Old 10-17-21, 07:30 AM
Aegean
Aegean's Avatar
Congratulations on your new car! I would immediately change the brake fluid since hybrids have a rather expensive actuator/abs pump system. Factory specifies this service every 30k mi/30 months
A service that is not in the maintenance schedule is to change the lifetime CVT fluid. Similar to the first break in oil change, the first time you change this fluid it is black probably form the CVT break in process. Then you will not need to change it again for long time. Maybe after 100k mi again and still fluid will look fine.
Due to your low mileage no other service appears that is needed. Spark plugs, coolant at 120 k mi/10 y and 12v battery at year 8 or 9. Brake pads at around 120k miles. Tires more often. Hopefully the hybrid battery will last 13-15 years before repairing a single module or replacing it with a new one.
Old 10-17-21, 07:35 AM
Maxitor
Maxitor's Avatar
Thank you for your detailed response I just scheduled a break fluid change and cvt fluid change! Also should I buy oem Lexus air filters or is the a Amazon brand good enough?
Old 10-17-21, 07:49 AM
Aegean
Aegean's Avatar
Filters could be aftermarket if they have good reviews. I do not think is that important like other parts. Fluids, batteries, spark plugs should be OEM on a complicated hybrid car.
Old 10-18-21, 10:54 PM
703's Avatar
Follow the maintenance schedule.
salimshah
Hybrid Technology
05-13-21 07:16 AM
avgj0F
IS F (2008-2014)
06-03-11 12:10 AM
i3urton
12-04-08 08:54 AM
themustafa
Maintenance
12
06-05-06 10:11 PM
Woogie
06-28-05 11:32 AM
Quick Reply: Just got a 2017 es300h what next?
