what kind of oil in 2013 ES?
#32
Lexus approved oil
Does anyone Know a source for the 'approved' oil? (cheap-er than the local dealer ?)
I know some engines are very picky on what works.... big problems for wrong oil. (and ATF).
*I normally drop the oil / filters at 1k-2k just to get any metal out from break in...
and what about the filters? anything special here?
assume a toyota hybrid (2.5ltr ) would fit?
thanks for bearing with the new guy!
-my old engine builder said his 'SAS Racing' stickers were worth 10hp! LOL -skipping the KN...
are the same; The oil requirement for the Avalon was 5w30 conventional oil - not synthetic.
I plan to change the oil in my 2013 back to conventional 5w30 after the first free change by the dealer. There is no valid reason to use synthetic over conventional oil. Add to that the increased cost of synthetics and there you are. Use any premium brand conventional oil and your car will run just as good as if you use synthetic oil. No good reason to pay for "Lexus" oil. Don't take my word for this - Google the question and you'll see...
#33
I traded a 2006 Avalon for my new Lexus 350. The engine in the Avalon and the Lexus
if you do 5k changes, probably fine. but at 10k changes, synthetic would be better.... IMHO.
(better in the cold/and heat extremes too)
IF (emphasis added ) you keep your cars over 100k.
also, an old trick was to add some marvel mystery oil (and get the oil hot), before the change to help flush any gunk...
-YMMV.
in my google search I found this to reset the oil change light.... too early to tell if it will work on the 300h.
http://www.ehow.com/how_6050089_rese...xus-is250.html
#34
Better additive package and longer change interval.Just about double the change interval.A few dollars more than dino oil with that change interval..
#35
fyi.... ebay is good source for factory filters and oil.
but frankly after watching some youtube videos on the canister filter... not sure I want to do this...
http://www.ebay.com/sch/i.html?_nkw=...at=0&_from=R40
http://www.ebay.com/itm/04152-YZZA1-...sories&vxp=mtr
#36
Ultra discount Toyota dealers like these two beat ebay prices on Toyota oil and filters:
29% off MSRP price at http://www.toyotapartszone.com/
28% off at http://www.partswebsite.com/1sttoyotaparts/
#37
With all the oil comsumption https://www.clublexus.com/forums/ls4...ion-issue.html and other wierd problems happening with Toyota's fragile engines nowadays I'd personally do an oil change every 3000 miles using Toyota OW-20 full synthetic to hold down wear to a minimum and to keep the engine as internally clean as possible (unless I was leasing).
#38
The thread pertained to the LS460 which is a V8 and not the V6 or 4 cyl (hybrid) used in the ES.
I've never read or heard anything that there is a oil comsumption problem with the V8, V6 or 4 cly used in various Lexus and Toyota models. Info from JD Power or Consumer Reports doesn't show any issues with these engines.
Personally, if I was buying a car and felt I had to do oil changes every 3,000 miles (with synthetic) I'd get something else.
#40
I think I read in the owner's manual that you can reset the service light in the Vehicle Settings. I could be wrong after going over a gizzion pages.
#41
See the Avalon maintenance manual:
http://www.toyota.com/t3Portal/docum...Avalon_WMG.pdf
Replace the oil filter and drain and refill the engine oil at specified intervals. For recommended oil grade and viscosity, refer to the Owner’s Manual.
NOTE: Your vehicle is certified with Genuine Toyota 0W20 motor oil. For VEHICLES CERTIFIED FOR 0W20 motor oil, the oil change interval is 10,000 miles or 12 months IF 0W20 MOTOR OIL IS BEING USED. If 0W20 is not available, 5W20 mineral oil may be used. However, it must be replaced at A 5,000 miles or
6 month INTERVAL with 0W20 motor oil
#42
Gents. I have been using Synthetic Oil (10W40) in my ES350-2013 Lexus that i currently drive in the Middle East (temperatures reaching 110 degrees Fahrenheit). I change my oil and filter every 10,000 km, even if the oil is still in a good condition. The car is running with no problems.
Is this the best oil to use ? or should i go for the other type of Synthetic Oils (5W30, 5W40). I was able to find an online manual for ES350-2013 car and it recommended 0W20. May be this is more suitable for the north American Climate.
Kindly assist.
Kindly assist.
#43
IMHO 10W40 is way too heavy an oil to use in this car. I might be okay using 5W30 in your climate, certainly 0W30 but I would not use 10W40.
#44
Kindly assist.
Kindly assist.
#45
