ES - 5th Gen (2007-2012) Discussion topics related to 2007+ ES350
drove my car in flooded waters
Old 03-08-15, 02:31 PM
jagtoes
jagtoes's Avatar
Originally Posted by deezstreet
in reply to JAGTOES the car smoothed out a heck of a lot ....the RPM now stays stable at around 1100 or so it does not really come down from 1000.
in reply to jkayca i did not change the coils, and yes they have been moved around and still the same issue.
so you suggest i remove some plugs and see if they are fuel wet?
when i removed the old ones they were fuel wet what does this mean?
OK if the car won't idle under 1000 rpm it is telling me you are running in open loop and are pumping to much fuel into the engine. What I don't know is are ALL plugs fouling or just one bank. Also you are most likely screwing up the O2 sensor. Does your temperature gauge move to normal as the car idles . What does the exhaust smell like , is it like raw gas. For some reason and I still suspect it is electrical the cold start (open loop) seems to be the way the engine is running and it will not go into closed loop.
Old 03-08-15, 03:04 PM
ESh
ESh's Avatar
Try to remove + wire from the battery for a couple of hours then try it.
Old 03-08-15, 04:06 PM
deezstreet
deezstreet's Avatar
the car idles at around 1000 rpm like i said before. the white smoke has a fuel smell. i stuck my finger in the exust and its oily like with moisture. i reran the computer once again and now i only receive a random misfire p0300 code. the temperature gauge goes to a normal position once it runs more than 10 mins
Old 03-08-15, 05:24 PM
mlacomb
mlacomb's Avatar
No check engine anymore? If so, fix the misfire first - then on to the next.. makes the most sense to fix what it tells you first before you go chasing other potential issues.
Old 03-08-15, 06:40 PM
jagtoes
jagtoes's Avatar
http://engine-codes.com/p0300_lexus.html
Old 03-18-15, 11:22 AM
deezstreet
deezstreet's Avatar
Default update
so what i was hoping for didnt happen ....happened! there is no compression in cylinder 2 or 4...so i hydro locked the car since there was no water in the oil (dipstick) i didnt think that was the problem but it was. luckily my mechanic is charging me $2500 for a new block with a head and labor ...i dont think its to bad...thank you all for your help i learned a whole lot.
once again thanks
Old 03-18-15, 01:18 PM
ESh
ESh's Avatar
Sorry to hear that mate.
covert
Performance & Maintenance
10-03-16 04:18 PM
Mythotical
07-18-13 10:49 PM
thebadz32
10-01-07 08:17 AM
usmarines
07-13-06 05:32 PM
LeXuSrAcIn
12-14-05 03:27 PM
Quick Reply: drove my car in flooded waters
