ES - 5th Gen (2007-2012) Discussion topics related to 2007+ ES350
RPM at highway speed
Old 12-28-14, 06:36 PM
MacG2014
MacG2014's Avatar
Default RPM at highway speed
I am wondering where I might find the approximate rpms for being in 5th and 6th at 70 miles and hour. I am wondering if it is shifting into 6th as the mileage is significantly lower than the AVG shown in the display.
Old 12-29-14, 12:37 AM
xanderES
xanderES's Avatar
If youre manually calculating the mileage then it is going to be more correct than the display. Are you looking at TANK AVG or just AVG? you know you can reset it by pressing and holding the display switch button right?
Old 12-29-14, 06:21 PM
oldgrump
oldgrump's Avatar
On mine with OEM wheels/tires (about 1/2 worn tires) at an indicated 60 mph the RPM in 6th is a tweak under 1800.
Old 12-30-14, 06:31 AM
unklexus
unklexus's Avatar
Mine is virtually dead on 2000 at 70 mph with new-ish Michelins. Recalibrated through the on screen setup when I bought the tires.
Old 12-31-14, 01:07 PM
MacG2014
MacG2014's Avatar
I am pretty sure it was tank average.
Old 12-31-14, 01:10 PM
MacG2014
MacG2014's Avatar
So between you and oldgrump above, mine seems to be right in there too. I was wondering if it was shifting into 6th or not but have since verified with manual shifting that it does in fact go into 6ht.
Thanks for your replies.
Old 12-31-14, 03:30 PM
christcorp
christcorp's Avatar
70mph?
Sorry, in wyoming we don't go that slow.
ramshyd
09-05-12 06:46 PM
HennessySK
CT 200h Model (2011-2017)
01-12-12 10:36 AM
Select
RX - 1st Gen (1999-2003)
10-05-05 01:27 PM
Quick Reply: RPM at highway speed
