ES - 5th Gen (2007-2012) Discussion topics related to 2007+ ES350
After Changing The Wheels, Low Tire Pressure Warning Light On
Old 11-12-14, 05:46 PM
babyduke
babyduke's Avatar
Default After Changing The Wheels, Low Tire Pressure Warning Light On
Last night, I changed to winter wheels and drove today with no problem. Just now one the way home, the low tire pressure warning light blinked for a minute and remained on. I checked the tire pressure and all 4 tires are even at 35psi. What can be wrong here? I tightened all wheels properly at 76 ft/lb using a torque wrench.
Old 11-12-14, 06:24 PM
Tetguy
Tetguy's Avatar
Check your spare. It should be at the same pressure.
Old 11-12-14, 06:59 PM
nevernu
nevernu's Avatar
did u change the button to the second set of wheels? thats the button under the glove box, pushed in is 2nd set of wheels. this is assuming u had the 2nd set of tpms programmed in.
Old 11-12-14, 07:03 PM
TerryTundr
TerryTundr's Avatar
I had this happen to me as well, bringing the car home from dealer. Anyway it was the right front sensor was broken. The light would not reset. The local tire dealer got a sensor at napa ....toyota type . Reprogrammed it . 82$ all set now
Old 11-12-14, 07:45 PM
babyduke
babyduke's Avatar
how do you program the 2nd set of tpms?
Old 11-12-14, 07:52 PM
nevernu
nevernu's Avatar
sorry dealer/some tire change guys have to do it with a machine
Old 11-14-14, 02:46 PM
w84me
w84me's Avatar
This might help : http://www.lexomans.com/manguide-553.html
Discusses how to reset TPM and also register 2nd set of wheels, and as mentioned, dealer will need to help with that.
Old 11-14-14, 08:15 PM
oldgrump
oldgrump's Avatar
Common chaps!.......the Owner's Manual and the Owner's Manual index can be your best friend.
gebo
GX - 1st Gen (2004-2009)
09-23-18 05:56 AM
ronron02
02-09-18 11:37 AM
Droberts12
07-01-16 02:09 PM
mcamson
03-28-16 04:42 AM
splitfire
11-05-07 09:45 PM
Quick Reply: After Changing The Wheels, Low Tire Pressure Warning Light On
