ES - 5th Gen (2007-2012) Discussion topics related to 2007+ ES350
Mod - adding USB socket for rear passengers
Old 08-12-14, 07:46 PM
GCL
GCL's Avatar
Default Mod - adding USB socket for rear passengers
I got tired of having to leave my center console door open when charging my daughter's electronics.
I decided to install a dual USB socket for her (Scosche reVOLT 12W + 12W Dual USB Car Charger). It's a good charger that can simultaneously supply 2 x 2.4 Amps. It's also small enough to fit behind the rear panel.
It is an easy mod. Drill a .75" hole, epoxy the charger in place, then tap into the lower wiring harness (pins 1 & 11: Red +, White w/ Black stripe - ) I also tried my best to match the interior by spray painting it with Fusion paint.
Old 08-13-14, 07:26 AM
SICK350
SICK350's Avatar
That's awesome, very good idea.
Old 08-13-14, 09:49 AM
crwmlw
crwmlw's Avatar
Default Attaching wires
Thats a great idea, how did you connect the wires to the charger? Which wires go where etc?
Old 08-13-14, 03:31 PM
crwmlw
crwmlw's Avatar
Default Also
What's the exact drill bit size? Does the USB port come apart to solder the wires?
Old 08-14-14, 03:30 AM
GCL
GCL's Avatar
The drill bit was 3/4". I had to file it larger just slightly (using a dremel). I also put a few shallow notches around the hole so that it wouldn't turn after I epoxied it in - just in case.
Yes, you do have to take apart the charger to solder in the wire. It splits in half using a thin putty knife. I then took out the metal tip and metal "wings", and soldered where the metal pieces attach. I think the tip is positive and the wings negative - I don't recall sorry. You can check with a multimeter.
Old 08-14-14, 07:43 AM
crwmlw
crwmlw's Avatar
Default Thanks
Thanks so much. I will have to do this
Old 08-14-14, 07:52 AM
crwmlw
crwmlw's Avatar
Default One more quick question
I have the charger, how did you manage to take it apart with a putty knife. I dont see where i can do it
Old 08-14-14, 08:08 AM
Nelexus88
Nelexus88's Avatar
Just a thought, you might want to consider installing a combo 12 volt + USB charger outlet to provide more options for the rear passengers. That would likely require a larger cutout however.
As you may know, the '13+ ES already have the 12 volt outlet in the back from the factory.
Old 08-14-14, 08:47 AM
crwmlw
crwmlw's Avatar
Default Thanks
Actually the only people that are ever in the backseat is our daughter or our daughter and a friend. The USB is plenty.
Old 08-14-14, 08:57 AM
GCL
GCL's Avatar
The charger that I used, seemed to be glued at the halves so prior to cracking them open I used a pair of vice grips adjusted to slightly smaller than the charger's diameter to crack the glue first.
Old 08-14-14, 09:13 AM
crwmlw
crwmlw's Avatar
Default Gotcha
Ok thats why, Ill try that in hopes it doesnt break
Old 08-14-14, 12:04 PM
GCL
GCL's Avatar
If you don't want to open it up, maybe you can just solder onto the metal tip and wing. That may work.
I didn't test this method though. (i.e. perhaps the tip needs to be pushed in to make contact). Also check the clearance if you leave the tip in place.
Old 08-15-14, 05:39 AM
SICK350
SICK350's Avatar
Where did u tap into for power? Does this only work when the car is on?
Old 08-15-14, 09:19 AM
GCL
GCL's Avatar
stripe - )
You need to cut open the plastic sheathing a bit. These wires operate the power outlet inside the console box, and they are hot only with the ignition/acc on.
I used T-tap connectors to make the connection. I may solder them in permanently in the future, but for now it'll be OK.
Old 08-15-14, 10:03 AM
GCL
GCL's Avatar
Quick Reply: Mod - adding USB socket for rear passengers
