ES - 5th Gen (2007-2012) Discussion topics related to 2007+ ES350
Mod - adding USB socket for rear passengers
Old 08-15-14, 12:57 PM
JerryM
JerryM's Avatar
Does that rear section just pop off the clips the whole way around?
Thanks for sharing!
Old 08-15-14, 03:12 PM
GCL
GCL's Avatar
Yes, first pull firmly from the bottom then pull straight back from the upper portion. It just clips into place.
Old 08-15-14, 03:52 PM
SICK350
SICK350's Avatar
Awesome, Thanks.
Old 08-15-14, 05:49 PM
GCL
GCL's Avatar
Originally Posted by SICK350
Awesome, Thanks.
No problem.
Old 08-16-14, 04:53 PM
Cjet
Cjet's Avatar
Nice job on this... I am going to put one in mine.
Old 08-18-14, 06:54 AM
JerryM
JerryM's Avatar
Me too. Thanks for this, GCL!
Old 08-18-14, 07:54 AM
SICK350
SICK350's Avatar
For anyone with access to a Canadian Tire store the Scosche Dual USB is on sale for $15.99. I included a link to the sale price.
http://www.canadiantire.ca/en/pdp/sc...l#.U_ITRNq9KSM
Old 08-19-14, 09:16 AM
crwmlw
crwmlw's Avatar
Default Duct Work
I was just about to attempt this yesterday but noticed how the duct work was attached to that panel that comes off. Seems like if I drill a hole on that panel that the duct work is about an inch and a half away making very little room for the usb socket?
Old 08-19-14, 09:25 AM
crwmlw
crwmlw's Avatar
Default See what I mean?
Old 08-19-14, 07:29 PM
GCL
GCL's Avatar
The above mentioned Scosche adapter will fit, with about 1/4" clearance (without the metal tip). If you are using another adapter you can slide a folded piece of paper into the area to compare the available room against your charger.
I like the Scosche one. It's super micro-sized and provides both ports with full 2.4A charging amps simultaneously.
Before drilling, remove the vent duct. It is attached by clips.
Old 08-21-14, 12:41 PM
crwmlw
crwmlw's Avatar
Default One more question
When you soldered the wires to the adapter did you gave to solder the spring with the wire for that center pin that pushes in or just the wire itself? the spring is attached to the circuit board so im not sure? Thanks
Old 08-21-14, 03:20 PM
GCL
GCL's Avatar
I cut, stripped, added heatshrink tubing, and then soldered to the wire itself (not the spring). I discarded all the metal spring/tips and wings.
You should probably do the positive tip wire first, and then the negative wires, just so that there is no mixup.
After testing to make sure that it works (I used a 12 volt wall adapter that I had lying around), I snaked the wire out the tip and then glued the case back together.
However. you might want to snake the soldered wires out the side, if possible. That will give you more clearance when you install the charger to the back panel.
Old 08-22-14, 09:53 AM
crwmlw
crwmlw's Avatar
Default Thanks
Thank you very much
MikeB139
04-08-19 05:50 PM
imjohnphan
08-12-17 09:59 AM
computerwi
NX - 1st Gen (2015-2021)
14
03-19-17 06:28 AM
lexnewbi
RX - 4th Gen (2016-2022)
12-07-16 03:29 PM
fj40ih8mud
05-05-13 04:11 PM
Quick Reply: Mod - adding USB socket for rear passengers
