ES - 5th Gen (2007-2012) Discussion topics related to 2007+ ES350
2009 Navigation map update
Old 10-21-13, 03:30 PM
2ksoftail
2ksoftail's Avatar
Question 2009 Navigation map update
I have the 12.1 u37 navigation disc. Can I do the update myself? A friend of mine has a LS and he has a drive in the trunck near the spare. Mine is not located there.......
HELP PLEASE
Old 10-21-13, 05:10 PM
ThumperPup
ThumperPup's Avatar
i think sometimes over the past 3 or so years they switched to HD systems
you should be able to update yourself if you have a map DVD
the latest one that just came out is U38 i think i have a U37 and not going to spend the money to update for another year or 2 i feel just 1 year is a waste of money usssualy in all my cars i only updated every other year the the most every 3 years
Old 10-21-13, 05:18 PM
2ksoftail
2ksoftail's Avatar
Thanks, Can you tell me how to do it.
Old 10-21-13, 06:07 PM
LexBob2
LexBob2's Avatar
There has been a lot of discussion here on DVD map updates. If you do a search, I'm sure you'll find the instructions. It's pretty easy to do.
Old 10-21-13, 06:16 PM
chbow
chbow's Avatar
I believe that 2009 ES350s still had DVD nav. If so your DVD is located under the moulding at the bottom of the screen. To remove the moulding pull up (not out) using your fingernail or similar. You eject the old DVD by pressing eject on the menu of the Nav screen (don't remember offhand exactly, but I think you go to map ver. / about map). Insert new DVD replace cover and you're done! More excellent and detailed info about this and other questions can be found by searching in the forum. Good luck!
Old 10-21-13, 07:25 PM
LexBob2
LexBob2's Avatar
Correct. 2009 was the last year for the DVD nav. 2010+ have the HD version.
Old 10-22-13, 03:41 AM
2ksoftail
2ksoftail's Avatar
Thanks Guyz, Piece of cake when you know where the disk is located!!
Old 09-30-19, 08:49 PM
Options2k
Options2k's Avatar
What generation is the nav on 2009 ES?
Thanks.
Naren
NX - 1st Gen (2015-2021)
24
10-17-17 05:01 AM
wread
RX - 1st Gen (1999-2003)
12-28-15 08:47 PM
miniz
04-07-12 04:59 PM
Radius9
08-09-02 02:34 PM
Quick Reply: 2009 Navigation map update
