ES - 5th Gen (2007-2012) Discussion topics related to 2007+ ES350
Help Me...Codes galore...need some insight...
Old 09-10-13, 09:56 AM
Nalley
Nalley's Avatar
Default Help Me...Codes galore...need some insight...
Hello,
Hoping somebody can shed some light on a list of codes I got on my 2007 ES350.
While driving last night - about 2 minutes into the ride my check VCS digital display came on, ecl light and TRAC indicator came on. I read through these threads before posting and see many have experienced this...using everyones past recommendations, I headed to AutoZone to get the Pcodes. Now that I have them, I am lost as to what to do with them.... Can someone help fill in the blanks/confirm and maybe even help me understand what they mean before I rush off to the dealer and spend money I cant afford to waste at the moment?
Here are the codes: (Ive notes beside each, what I was able to find for them - feel free to correct...
P1201 - brakes/calibers
P0371 timing reference High Res A too many pulses
P0057 oxygen sensor
P1271
P1272
P1273
P1274
P1275
P1277
P1278 air fuel ratio
P1281
Pardon if the answer to these is obvious - Im a girl - who admittedly knows very little about this...but appreciate any insight any of you may be able to offer....
Thank you in advance
Old 09-10-13, 09:53 PM
nevernu
nevernu's Avatar
dont have time to do any research now but usually the first few codes are the key ones and the rest disappear after those are sorted. so i dont know if u sorted the numbers or if they came up in that order in the readings.
Old 09-10-13, 10:13 PM
oldgrump
oldgrump's Avatar
You have an engine operating/performance issue.......the P1201 code has nothing to do with brakes........it's an engine air/fuel metering fault code. The P0371 code is a camshaft sensor/circuit code, I believe, & which could be the root cause of the problem. You can look them up here: http://www.actron.com/code_lookup.php
LCC
06-25-19 12:03 AM
jhaas10
RX - 1st Gen (1999-2003)
04-07-14 07:48 PM
Nalley
Maintenance
09-12-13 05:17 PM
Tony95sc4
SC- 1st Gen (1992-2000)
10-25-06 10:36 PM
usmarines
Performance
08-24-06 07:47 AM
Quick Reply: Help Me...Codes galore...need some insight...
