ES - 5th Gen (2007-2012) Discussion topics related to 2007+ ES350
factory amp location
Old 08-09-13, 06:05 PM
mikewu9900
mikewu9900's Avatar
Default factory amp location
i am brand new to this site, but pretty experienced with forums... on the 4th of just i bought my 4th ( and nicest to date ) Lexus... its an 08 es 350 pearl white and certified preowned.... pretty sweet.
anyways, i looked on the forum and Google search with no luck, the location of the factory amp location. im wanting to add a sub and amp, which i know i could just tap off the factory sub, but also wanted to change the factory sub and install an 8 inch pro audio speaker for better mids and run off the other side of my 4 channel amp. im guessing the factory sub has a xover, so i am needing some full range inputs for the pro audio speaker. instead of pulling door panels and all that, i just figured i can tap off the factory and and be done with it...
does anyone know where the factory amp is located? i haven't looked for it yet but thought someone on here would know where it is... thx in advance
Old 08-10-13, 06:05 AM
mlacomb
mlacomb's Avatar
It is located in the trunk, passenger side. I tapped the front speakers' connections when putting in my sub using vampire taps.
Old 08-10-13, 11:48 AM
iceblast
iceblast's Avatar
So do you have to lift up the carpet to access the amp? I haven't made the attempt to look yet.
Anyone who thinks they need the wiring diagram, I have it, and can probably give you the wire colours you need.
Old 08-11-13, 06:02 AM
mlacomb
mlacomb's Avatar
It isn't on the floor, it is bolted to the side brace for the trunk mechanism. If I recall I had to pull the plastic piece from the lower trunk lip but I too have the wiring colors around here somewhere...
Old 08-12-13, 07:29 AM
mikewu9900
mikewu9900's Avatar
i would like to have the wire diagram. i would like to jump off the rear door speakers... thanks
Old 08-12-13, 09:10 AM
nevernu
nevernu's Avatar
think this is the diagram u want
File Type: pdf
Denvergal (03-29-18)
Old 08-12-13, 02:58 PM
mlacomb
mlacomb's Avatar
I personally pulled from the front speakers for a sub and it has full range, might want to consider that off you ever want a simple tap point for a full range amp
Old 08-13-13, 09:57 AM
mikewu9900
mikewu9900's Avatar
good idea... did you pull from amp or from speakers? if you pulled from the amp, what are the wire colors? the diagram from a few posts up, was a little complicated. thx
Old 08-14-13, 06:35 PM
mlacomb
mlacomb's Avatar
Front Left + Pink
Front Left - Purple (Violet)
Front Right + Light Green
Front Right - Light Blue
I used vampire taps directly at the output of the amplifier in the trunk. I initially was silly and just shoved wires into the plug, but they came loose. All four of these colors are on one plug. If I find my other install notes, I'll share. Let me know if you run into trouble.
Old 08-14-13, 08:20 PM
nevernu
nevernu's Avatar
Front Left + Pink
amazing just like the wiring diagram says lol
Old 08-19-13, 08:34 AM
mikewu9900
mikewu9900's Avatar
Front Left + Pink
thanks a lot... just looked like the diagram had a few different models.
Old 11-28-19, 09:45 AM
YohanC
YohanC's Avatar
Default Having trouble finding the amp location
i been looking everywhere for the amp location and i cant find it do you mind sending me a picture of where it is?
SSmith
SC400 / 300 Classifieds
08-15-13 11:54 AM
kmn5
02-16-06 09:01 PM
sexilexi
08-29-05 04:23 PM
SCFriend
13
07-13-04 04:45 PM
1UZFE
10-31-03 09:29 AM
Quick Reply: factory amp location
