phone bluetooth connection ?
I was wondering
when i turn my phone off if the car is on and then turn my phone back on after its already been connected to the bluetooth it won't reconnect unless i turn the car off and then reboot by turning the car back on
is there a way i can reconnect via B/T without having to turn the audio system off then back on ?
i can't find a function to connect without doing so thank you
Are you following the instructions on page 109 of your navigation manual?
If the Bluetooth phone is disconnected
with a poor reception from the
Bluetooth network when the engine
switch is in the “ACC” or “IG-ON”
mode, the system automatically reconnects
the Bluetooth phone. In this
case, the connection result is not displayed.
If the Bluetooth is disconnected on purpose
such as you turned your cellular
phone off, this does not happen. Reconnect
it by the following methods.
Select the Bluetooth phone again.
Enter the Bluetooth phone.
i don't have the navigation manual for my vehicle
thank you for the information
Yeah; the system doesn't try to look for phones after about a minute if it doesn't find a pairing. I just go through the system prompts (voice) and do setup - phone setup - select phone - list phones (I always forget what I called it) and go from there.
keziah23
RX - 3rd Gen (2010-2015)
15
05-23-19 01:23 PM
frebay
08-03-05 04:17 PM
