ES - 5th Gen (2007-2012) Discussion topics related to 2007+ ES350
Replacement of Tires
Old 05-07-13, 07:46 AM
lakwill
lakwill's Avatar
Default Replacement of Tires
I have a 2010 ES350 with Michelin Energy Tires. I intend replacing the 4 tires with Bridgestone - Ecopia EP422 (eco) which has a better tread life and fuel efficient.
Has anyone used these tires in a luxury car? Thanks.
Old 05-07-13, 04:34 PM
flowrider
flowrider's Avatar
Received 1,826 Likes on 1,288 Posts
Look here:
http://www.tirerack.com/tires/survey....jsp?type=GTAS
And at the attachment.
Lou
Old 05-08-13, 09:14 AM
lakwill
lakwill's Avatar
Thanks for the information. I will stick with Michelin Primacy MXV4.
Old 05-11-13, 04:10 AM
Paul3637
Paul3637's Avatar
Default Go Primacy H rated MXV4
Primacy is a fantastic tire
https://www.clublexus.com/forums/es3...ml#post7044176
See post #11 of that thread.
Primacy is best is also all over camry & Avalon forums
http://www.toyotanation.com/forum/10...012-issue.html
Old 05-12-13, 05:21 PM
kreativ
kreativ's Avatar
Does the v-rated Michelin Primacy MXV4 rank as high as the h-rated version?
Old 05-13-13, 07:56 AM
Paul3637
Paul3637's Avatar
No ....... at least according to Consumer Reports testing (overall 70 for H rated, 66 for V rated). Although it does better in wet braking, it is not as good in ride, noise, & rolling resistance.
The UTQG treadwear rating of the H rated 215/55/17 is 620 while the UTQG of the V rated is 500.
The V rated Primacy is a fine performer nonetheless and carries the same 60K mile treadwear warranty from Michelin as the H rated. It is one of the standard OEM tires now on 2013 Lexus ES, Avalon XLE, & Camry XLE.
Most people will do fine with the H rated Primacy. For spirited driving .......... or curvy roads in the mountains ...... probably the Primacy MXM4 is the best V rated performance tire. It comes standard on 2013 Camry SEV6 and Avalon Touring with 18" wheels.
Old 05-14-13, 12:08 AM
kreativ
kreativ's Avatar
My local Costco tire center told me that I would have to sign a disclaimer and it would void the treadwear warranty if I put H-rated tires on my Lexus ES350 because this model calls for V-rated tires.
Any truth to that, or should I just go elsewhere for the H-rated Primacy MXV4?
Old 05-14-13, 12:10 AM
kreativ
kreativ's Avatar
I've read some people using 225/55/17 Primacy MXV4 on the Lexus ES350. Is it just personal preference on how it looks, or are there other benefits?
Old 05-14-13, 01:32 AM
Chocolate
Chocolate's Avatar
I use 225/45/R18 Primacy MXM, V-rated on my ES330. Previously, I had Primacy MXV4, H-rated 205/60/R16 on the stock wheels. Both ride quiet and smooth with minimal noise.
Old 05-16-13, 07:58 AM
Paul3637
Paul3637's Avatar
Absolute BS. My H rates on my camry v6 (same powertrain & 17" wheels as ES) were purchased at NTB in Kansas City with no caveats. They have 48K miles on them now and will go to 60K if I want to push it .... but will probably be replaced at 55K to be safe. OEM Turanza's lasted 8,500 miles.
My H rated Primacys handle WAYYYYYYYYYYYYYY better than the OEM V rated Turanzas. Costco was willing to put H rated on my (ex) wife's ES ...... but NTB did a price match so we got the H rates at NTB.
Old 05-16-13, 09:06 AM
flowrider
flowrider's Avatar
H or V ratings are speed ratings, and in North America are installed by the manufacturers based on the top speed capability of the vehicle it's installed on. They are an indication of how well a tire will handle heat buildup, which increases as road speed increases. Generally H rated tires tend to ride more smoothly and have more tire life than V rated tires. V rated tires usually handle a bit better than H rated tires. With that being said, my wife's ES350 has H rated Michelins, My ISF has Y rated Bridgestones, and our Silverado has T rated Michelins. The ES is not a spirited handling machine, my F is. The ES will never be near the 130 MPH speed limit of an H rated tire, my F has exceeded that number and will in the future.
IMHO, a good H rated tire is a better choice for an ES than a V rated one.
Lou
Old 05-16-13, 01:42 PM
ThumperPup
ThumperPup's Avatar
the Primacy is a great tire i like alot better then the Turanza that was on the car
i replace with Primacy a few months ago and they are really aweomse
Old 05-17-13, 07:29 AM
LHH
LHH's Avatar
Default Bridgestone Serenity Plus Tires
Check out the Bridgestone Turanza Serenity Plus tires. They are quite, very good in rain and are rated at 70k or 80k mileage.
I replaced the original Michelins and they are the best all season tire I have ever used.
Old 05-19-13, 07:18 AM
flowrider
flowrider's Avatar
∧∧∧∧The Bridgestones you mention seem to be a new tire, and appear to be well liked by the survey responders at Tire Rack.
Lou
Old 05-19-13, 06:05 PM
kreativ
kreativ's Avatar
I was set to get the H-rated Michelin Primacy MXV4, but I ended up going with the Michelin Primacy MXM4 (V-rated) because it was $159.99 per tire (Costco's price was $196.99) along with a Buy 3 Get 1 Free sale currently going on at American Tire Depot in CA. $612 out the door with installation. I would've paid more than that for the H-rated Primacy MXV4 at Costco even with the $70 Michelin discount they're currently running ($634 out the door).
Quick Reply: Replacement of Tires
