ES - 5th Gen (2007-2012) Discussion topics related to 2007+ ES350
Need advice to get rid of odor inside cabin
Old 04-26-13, 05:25 PM
harmonytom
harmonytom's Avatar
Default Need advice to get rid of odor inside cabin
Bought this 2010 ES 350 before last winter, never use the air-con until last week. After the air-con was turned off, here comes the odor! The fumes’ were so bad that I had to open up all the windows. Did take out the air filter to clearn, but odor still come back after air-con was turned off.
Please advise how to get rid of this odor, many many thanks!
Old 04-27-13, 07:36 AM
garsarno
garsarno's Avatar
Had same problem with '99 Town Car and it was from some time of drain plug in the a/c system not open and not letting the water run out, hence the smell. Dealer will clean out unless a member here will advise on how to check and clear the system.
Old 04-27-13, 02:24 PM
oldgrump
oldgrump's Avatar
As mentioned check that the evaporator drain is clear to ensure that the normal condensation can drain. Has the cabin air filter been changed? Also, to help prevent odors which is aggravated by moisture remaining in the evaporator when the car is not being driven, turn off the AC (in other words......turn off the compressor) a few minutes before turning off the engine (keep the fan running).
There is also an old saying related to automotive AC that states.......use it......or lose it. It is wise to engage the compressor (AC "on") for a few minutes (at least) every time the car is driven (once on the daily trip, kinda thing).
Another old automotive saying......use the parking brake.......or lose it.
Old 04-28-13, 04:28 PM
harmonytom
harmonytom's Avatar
Thank you guys, can you advise more on how to "check that the evaporator drain is clear to ensure that the normal condensation can drain."?
Old 04-28-13, 05:50 PM
garsarno
garsarno's Avatar
My local garage knows how to check them. Maybe yours does too or you may need to take it to your Toyota or Lexus dealer. I used to work at Avis and to get rid of an interior odor, we would spray Febreeze into the air intake at base of outside windshield and run the windshield defroster to relieve any smells in the car.
Old 04-29-13, 07:42 AM
jcat_350
jcat_350's Avatar
^^the febreze trick is 'quick and dirty' and by no means a permanent solution.
Steps to take for interior odor:
1.) CHANGE THE CABIN FILTER!! They can get musty over time.
2.) The AC drain will be a white/clear plastic tube coming down just behind the front wheels. You'll have to search for it, or you can just let the car run with the AC on for a while and look for where it's dripping from. You can use an untwisted coat hanger to get up into the tube and knock loose whatever junk is in there. Just be careful to not pull the tube off.
3.) Be sure the header panel (below the windshield with the slots in it) is clear of any debris, inside and out. It's actually pretty easy to remove and once you do, you'll be able to either vacuum out any junk or blow it out with compressed air.
Old 04-29-13, 09:59 AM
harmonytom
harmonytom's Avatar
Very useful infomation from you guys, thanks a lot!!
Old 04-29-13, 11:00 AM
chbow
chbow's Avatar
You might also want to try the toyota AC spray (http://lexus.sewellparts.com/accesso...2010/4481.html). I've seen threads here detailing how to use it.
aachowhan
10-13-19 07:53 AM
Brabusx2
07-08-17 11:56 PM
LexusGuy91
04-12-15 05:37 AM
msarahalex
03-18-12 09:35 AM
xcantuaj
03-01-07 07:25 AM
Quick Reply: Need advice to get rid of odor inside cabin
