ES - 5th Gen (2007-2012) Discussion topics related to 2007+ ES350
constant beep when I enter unlock and enter car
Old 10-03-12, 08:34 PM
provlima
provlima's Avatar
Default constant beep when I enter unlock and enter car
Sometimes when I unlock and open drivers door to enter the beeping stays on till I close the door.
Normally upon unlocking and entering the beeping is heard for one second only.
What is causing the continuous beeping sometimes??
Thanks for your help!
Old 10-03-12, 08:38 PM
jcat_350
jcat_350's Avatar
are you accidentally hitting the button on the door handle as you're entering the car with the door already open? This sends a signal to the car to lock the doors and when it detects one still open, it beeps like that.
Or, I could see it being a low battery warning for the proximity key. Have you noticed your remote range going down lately?
Only other thing I can think of is if you hit the lock button on the proximity key when the door is already open.
Old 10-04-12, 04:22 AM
Poqman
Poqman's Avatar
Could another door be unsecured or your moon roof open? I get the warning when I turn off the car and open the door if I've left the moon roof open.
Old 10-05-12, 03:10 PM
jacobjohn
jacobjohn's Avatar
i agree with jcat. You most probably hit the door button again, telling the car to lock while the doors are open and you'll get that long annoying beep as a result.
Old 10-09-12, 05:19 AM
provlima
provlima's Avatar
Default solved!!
Thanks for your input...you were right on the money!!
For future owners who encounter this problem...........
I was touching both the inside black switch as well as the outside one when opening the door.
This has also taught me that touching the black plastic nub on the handle also is a third option for locking the car doors. I have owned the es350for two months and found there is quite a learning curve to today's high tech cars
Nomis
Performance & Maintenance
36
07-27-24 02:01 PM
braddman
04-23-21 09:01 PM
Lohus
03-22-15 01:13 PM
DOHCZ34
11-14-09 10:39 PM
07IS250
12-26-06 12:12 PM
Quick Reply: constant beep when I enter unlock and enter car
