ES - 5th Gen (2007-2012) Discussion topics related to 2007+ ES350
any way remote can open windows??
Old 09-07-12, 06:38 PM
provlima
provlima's Avatar
Default any way remote can open windows??
Is there a way the remote can be programmed to open all the car windows before you get in on a hot day??
Old 09-07-12, 07:02 PM
LexPaul
LexPaul's Avatar
Yes, press and hold down the 'open-lock' button on the key fob until the windows open and if you keep holding the button down it will open the sunroof as well. I believe the remote is programmed this way automatically from the dealer at no charge. Have you tried the above method?
Old 09-08-12, 12:12 PM
SatComm302
SatComm302's Avatar
My remote will not lower my windows. I can hold the button in on the door handle and it will raise my windows. I'll have to check with the dealer on why I don't have the window-down feature. It may have been accidentally disabled.
Old 09-08-12, 12:44 PM
Tact
Tact's Avatar
I just tried this method and my windows roll down by holding down the unlock button. However, it doesn't roll the windows up while holding the lock button. I assume this is normal?
Old 09-08-12, 01:05 PM
Joeb427
Joeb427's Avatar
After never using the feature on any Lexus I've owned and seeing my neighbor's ES with moonroof and windows open in the rain after probably sitting on his keyfob or whatever,I asked my service advisor to eliminate that feature on my '12.He said Lexus took the feature off the '12's.
However,it can be programmed back if desired.
Normal.
Old 09-08-12, 01:17 PM
Timothyj
Timothyj's Avatar
This works on my 04ES. Opens the sunroof also.
Old 09-08-12, 08:38 PM
CQRT
CQRT's Avatar
YUP . . . same with mine . . .
Old 09-08-12, 11:37 PM
chbow
chbow's Avatar
Except with the Ultra the sunroof doesn't open. I suppose for the same reason we don't have one touch open / close.
Old 09-09-12, 07:36 PM
Lexinky
Lexinky's Avatar
[QUOTE=Joeb427;7472637]After never using the feature on any Lexus I've owned and seeing my neighbor's ES with moonroof and windows open in the rain after probably sitting on his keyfob or whatever,I asked my service advisor to eliminate that feature on my '12.He said Lexus took the feature off the '12's.
Too bad the windows and moonroof don't close automatically via the windsheild wiper rain detector.
Old 09-10-12, 05:05 AM
Joeb427
Joeb427's Avatar
[quote=Lexinky;7474656]
That would be a great and probably not very hard to program in.
Old 09-10-12, 05:29 AM
Lexinky
Lexinky's Avatar
I would bet they thought of it and I bet it could be done. There is probably a reason they don't do it
Old 09-10-12, 06:48 AM
chbow
chbow's Avatar
Maybe I'm missing something, but I never understood why holding the lock button on the fob doesn't close all the windows and you have to push the handle button. Anyone know why?
Old 04-13-17, 12:05 AM
nisanthcp
nisanthcp's Avatar
Lexus Remote open and Close Window and Moonroof
How to do video :-
Old 04-13-17, 03:46 AM
lgb0250
lgb0250's Avatar
There are tons of things that you can program yourself by either having techstream or Carista. I've had Carista since it was first introduced and use it on both of my vehicles and my daughters Sienna.
flystone
09-15-14 11:51 PM
TomLS
06-22-10 08:03 AM
flboater
GX - 1st Gen (2004-2009)
08-17-09 02:51 PM
BottomsUp
04-01-07 06:38 PM
CLK
RX - 1st Gen (1999-2003)
08-05-03 10:12 AM
Quick Reply: any way remote can open windows??
