ES - 5th Gen (2007-2012) Discussion topics related to 2007+ ES350
Rear Passenger Doors
Old 08-29-12, 11:48 AM
jacobjohn
jacobjohn's Avatar
Default Rear Passenger Doors
Anyone else find it difficult to close the rear doors on the first go? I recently noticed that you would need to push the rear doors harder than you would for the front doors. I know the rear doors are longer than the front, but is this normal for everyone? It seems like it loses a lot of momentum as the door rotates, which could be the culprit. I bought the car in December and didn't really notice it until now...maybe I'm just bored and looking for things to fix?
Old 08-29-12, 03:21 PM
sanjaysdca
sanjaysdca's Avatar
Try opening the window/door on the other side and see if it closes properly.
If not you have a problem
If yes then it is normal. Closing the door when all other doors and all windows are close will need more "force" due to back (air) pressure
Old 08-29-12, 04:18 PM
CQRT
CQRT's Avatar
does it just not latch ?
Old 08-31-12, 01:16 AM
dreyfus
dreyfus's Avatar
No, I haven't noticed that on mine.
Old 09-02-12, 08:40 AM
jacobjohn
jacobjohn's Avatar
it latches, it just takes an extra effort to close the rear doors for some reason. I tried the window trick to see if its the extra pressure, but that wasn't the reason. hmmm...
Old 09-02-12, 11:15 AM
garsarno
garsarno's Avatar
There might be some slight adjustment that the dealer can do to the latch.
Old 09-02-12, 01:16 PM
jacobjohn
jacobjohn's Avatar
possible. Thanks for the help. i will go ask them when I have some free time!
Old 09-05-12, 01:16 PM
glepera
glepera's Avatar
your door is out of alignment. sometimes the latch moves a bit all it takes is a wrench to reset the latch on the body panel side back to the correct setting. what's happening is you are hitting metal now and then you kind of nudge it into place. It's as easy fix, don't stress it. good luck
texves
06-11-15 06:57 PM
hlu
RX - 1st Gen (1999-2003)
01-07-14 07:35 PM
akfd
GX - 2nd Gen (2010-2023)
06-15-10 06:36 PM
slowtan
08-29-03 08:58 PM
LB Lex
GS - 1st Gen (1993-1997)
14
05-04-03 12:34 AM
Quick Reply: Rear Passenger Doors
