ES - 5th Gen (2007-2012) Discussion topics related to 2007+ ES350
Tire pressure sensor
Old 05-31-12, 08:40 AM
frotiss
frotiss's Avatar
Default Tire pressure sensor
I have a 07 ES350 the tire light came on I don't have a manual can somone tell me how to reset thanks
Old 05-31-12, 10:05 AM
Tact
Tact's Avatar
You must have one or more tires low on air. Once you air your tires up to the proper inflation the light should reset once you start to drive.
Old 05-31-12, 10:13 AM
frotiss
frotiss's Avatar
It didn't go off what else can I do
Old 05-31-12, 10:48 AM
rx300mm
rx300mm's Avatar
To reset this light reach your hand down under the dash, under the steering wheel. You will feel two buttons. The one on the right enables and disables the traction control and the one on the left resets the tps light. Hold it in for about five seconds and the light blinks a few times and then goes out. Do this is all done with the engine on, of course don't forget spare tire has to be same pressure, the tps system checks all 5 tires
Old 05-31-12, 01:33 PM
Tact
Tact's Avatar
I'll bet your spare is low.
Old 05-31-12, 03:24 PM
LexBob2
LexBob2's Avatar
Yeah, if the car has a full size spare, it's easily overlooked.
Old 05-31-12, 04:38 PM
marvinje
marvinje's Avatar
same thing happened to me, but all I had to do was put air in the tire and the light went off
Old 05-31-12, 04:42 PM
frotiss
frotiss's Avatar
okay thanks will check it
Old 06-01-12, 04:59 PM
retired
retired's Avatar
Bring the pressure to 31/32 psi for all five tires...when they are cold....Dont forget the spare///This should take care of the indicator light..The manual calles for 30 psi, but 32 is acceptable
Old 06-01-12, 08:31 PM
Received 2,500 Likes on 1,803 Posts
I bet its the spare.
I run all mine at 30 as per the door sticker, I don't like the way the car rides on 32. If the light still comes on, you can reset it to the proper pressure by holding down the switch.
So Philly1
12-18-13 06:08 PM
tyb2639
GX - 1st Gen (2004-2009)
01-21-12 07:08 PM
snakehead
03-21-10 10:03 PM
Leonard15
10-18-09 07:27 PM
suxelsuxel
10-24-08 07:47 AM
Quick Reply: Tire pressure sensor
