New to the forum with a couple questions
Hello all! I just picked up a 2007 ES350. I did a little searching but it seems most folks have the upgraded sound from the posts i read. I have what i guess is the basic system. In dash changer, separates in the doors up front and a single sub in the rear deck. No tweets in the dash. I am looking to keep the stock setup in the dash but will be replacing the speakers and installing aftermarket amplification. Does anyone have the pin-out diagram/wire color codes for the back of the in-dash unit? Also, what would you say is the best way to add an aux input to the system. Thanks in advance, Jeff.
You can't connect an aftermarket amp to the head unit. Think of the head unit and factory amp as a single piece. They were made to work together. You either upgrade the head unit and use an adapter to work with the factory amp or you tap into the speak outputs in the trunk to feed your new amp.
You already have an aux input in the arm rest. There are a few aftermarket iPod/iPhone interfaces. What are you planning on using the aux input for?
Not sure, but the OP may have been refering to the Mark Levinson sound system when mentioning "upgraded sound."
Regardless, it does seem like most owners don't upgrade their sound systems. We found the standard sound system in our ES to be so much better than the Hondas we have owned that we aren't motivated to upgrade. OTOH, all Hondas need to be upgraded.
I have an 06 Accord, i know all about the horrible sound system!
Anyway, I was wondering where the amp is located if not under the passenger seat on the non, ML systems?
That's why everyone is different. I find the standard sound system to be slightly above horrible. Even a front speaker swap makes a huge difference.
If....
There are less than 10 people who have upgraded speakers, a couple have added a DVD/Nav aftermarket setup and I'm the only one that has replaced the head unit. Based on the number of aftermarket install kits sold from the only supplier, there's about a dozen TOTAL of us who have upgraded their head unit.
At least the front speaker outputs are full range. Again, this is why adding a new head unit helped the sound so much. I use my Pioneer's crossover to filter out the lows before sending it to the factory amp. That amp is very capable when it doesn't have to reproduce 80hz and below.
Aux input for the factory radio - http://www.youtube.com/watch?v=UN6N8pTrKNU
I don't have the time right now but I'll zip up the tech manuals for the 350 and send them to you. PM me your real e-mail address. The detailed instructions for getting to the amp as well as pin-out/wire color are in there.
XSTeknique
04-20-07 09:55 PM
