ES - 5th Gen (2007-2012) Discussion topics related to 2007+ ES350
Question regarding 2008 ES350 Bulbs
Old 10-27-11, 07:42 PM
azncapcom
azncapcom's Avatar
Default Question regarding 2008 ES350 Bulbs
I have a 2008 ES350 Premium Package (Canadian Version). I know the car comes with HIDs. My question is, is it only the low beams that are HIDs? What about the high beams? Are they HIDs as well?
Old 10-27-11, 07:50 PM
LexBob2
LexBob2's Avatar
In U.S. versions only the low beams are HID. Not sure about Canadian models but would think they are the same.
Old 10-28-11, 04:22 AM
garsarno
garsarno's Avatar
The high beam light bulb is size 9005. Plenty of brighter white bulbs on the market. Take a look at the Sylvania and Hoen USA websites. Some of the bulbs need a heavy duty "pigtail" wire and connector to handle the increased wattage, esp the HID look bulbs available at Hoen USA. Thinking about getting a matching HID look alike for the high beams too on my 2011.
www.sylvania.com and www.hoenusa.com websites.
Old 10-29-11, 03:13 PM
azncapcom
azncapcom's Avatar
So i would have to replace the OEM wire? is that a simple task? I mean yeah it should be easy to replace the wire but is it easily accessible?
Old 10-29-11, 11:32 PM
tC350
tC350's Avatar
Their Halogen high's
Old 10-30-11, 11:48 AM
garsarno
garsarno's Avatar
They have a plug and play connector set that has heavy duty plastic and connections. Goes for $20 per pair plus shipping.
Old 11-06-11, 11:46 AM
buttons
buttons's Avatar
Running 100 Watt super white 9005s in my 2008 ES350. No wire change or anything else ( divide by 12 and get the amps: low). Have run 100 watts since 1979 in my cars--never a problem--and you can see deer on the road lots better. I always buy from JCW. Note that DOT says run them off-road only.
Old 11-06-11, 03:05 PM
azncapcom
azncapcom's Avatar
I dont know if i want to go 100W. Maybe just a bright 55w
Old 11-06-11, 08:28 PM
buttons
buttons's Avatar
Ride with someone having the 100W and you will want them !! I ran 400watts in a 635CSI Euro.:: two 100w H-1s and two100w H-4s halogen and that was with CIBE Z beams--awesome. 4.58 amps vs 8.33 amps per light is certainly no concern. Z beams had the same cutoff as the HID and that was in 1986. Low beam was 80W on the H-4s. This technology has been around for a while~~~
gianttama
03-30-17 08:25 AM
koreanguy9
10-19-14 06:43 AM
arnieosp
09-29-10 03:38 PM
tacomike
05-04-10 04:24 PM
WinesRus2
06-22-08 05:50 PM
Quick Reply: Question regarding 2008 ES350 Bulbs
