Car broken into 2007 ES350
My front passenger side window was smashed. When i went to try and get the car started there was no power. I got it jumped and now it only goes 20 mph. the check engine light is on and check vsc light. the car is a 2007 ES350. Any help would be great.
Simple - if the CEL light is on, you need the code read. Have it towed and checked out!
Most likely not a simple fix, but I'm guessing your insurance company will cover it anyway.... so take it to a Lexus dealer if it's not on your dime.
MDames2 is right - your car can be jumped without any problems and your symptoms point to something more serious. Anywhere you can get your CEL code read will point you in the right direction. A trip to the dealer is probably in order.
I read that the factory alarm only goes off if they try and to open the door from the inside. I assume they broke the window and tried to open the door. They only got my ipod.
It seems that because the battery was so drained it might have messed up the computer.
Hmanan
ES - 5th Gen (2007-2012)
05-09-12 06:37 AM
boss22
05-02-12 04:58 PM
forumsview
11-24-10 03:38 AM
