ES - 5th Gen (2007-2012) Discussion topics related to 2007+ ES350
Mama don't put no 37psi in those ES350 tires
Old 10-05-11, 12:45 PM
riles3019
riles3019's Avatar
Default Mama don't put no 37psi in those ES350 tires
Was soooo disapointed in new MXV4 Primacy tires. Tire people filled to 37psi [same as I did in my '04 es330 to stiffen up the ride and handeling]
The rebound out of a minor road dips was like a bucking horse. Checked psi and was 37. Lowered to recommended 30 and ride/handeling is perfect, in my opinion.
Old 10-05-11, 07:10 PM
frankbcnt
frankbcnt's Avatar
Everytime I bring the car into the dealer they up the tire pressure 35-37. always gotta bring it down ...
Old 10-05-11, 07:40 PM
LexBob2
LexBob2's Avatar
Same here. And I always forget to ask them why they do it and to tell them not to do it on my car. Maybe one of these times I'll remember!
Old 10-07-11, 11:47 AM
garsarno
garsarno's Avatar
My new one had 37 psi including spare. Adjusted to 32 psi for tires on car and 35 psi for the spare.
Old 10-09-11, 08:37 AM
Road Rage
Road Rage's Avatar
The reason the dealer pumps them up to close to 40psi is because Lexus tells us to. I won't go into the formula here but a car coming in with hot tires is supposed to be aired up to 39-40psi to compensate for when it sits overnight and the tires cool down. After this overnight cool down the tire light will come on if the pressure is set too low. This leads to a lot of come backs.
I'm a little less lazy with the cars I work on and apply the formula to the tire placard on that car as not all are the same. For instance a GS is usually 33psi, while an IS might be 35 front and 38 rear. Most techs just use the same number for everything.
For those that purchased a brand new Lexus and found the COLD TIRE PRESSURE to be too high then they were not correctly set during the Pre-Delivery Inspection. Of course if your checking the pressure after driving then the tire will be hot and the results skewed.
HappyUp
NX - 1st Gen (2015-2021)
58
02-05-18 09:48 AM
lodgikall
RX - 3rd Gen (2010-2015)
11-20-11 06:42 AM
cdvmagic
Wheels, Tires & Brakes Forum
10-10-07 03:39 PM
ToyotaLexus
RX - 1st Gen (1999-2003)
20
11-11-06 09:53 AM
Carnaught
09-16-02 05:36 PM
Quick Reply: Mama don't put no 37psi in those ES350 tires
