ES - 5th Gen (2007-2012) Discussion topics related to 2007+ ES350
Old 12-16-14, 11:37 AM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Lexus IS Lighting Guides
Print Wikipost
DIY: Lexus ES350 Footwell Lighting
Old 04-09-13, 07:25 PM
  #31
RTSM
RTSM's Avatar
I did this mod as well. With the amber lights I could not even tell if they were on (black carpeting).
Thanks ekwlee for the write up to get us all to do this mod. Simple, and the white light is much better then the amber ones.
Old 04-21-13, 05:54 AM
  #32
smarty666
smarty666's Avatar
You can also go to your local Lexus part's department and order a pair of the IS250/350 foot well lights. They are white and that is what I used to replace the god awful yellow/amber foot well lights that come OEM in the ES350. That is what I did plus you get Lexus original equipment in the process. I think I paid $13 for the pair. Took about 5 minutes to swap them out.
This is another way you can do it as well. Can't for the life of me figure out why Lexus put those ambers standard, especially considering the overhead center console ambient light is white, lol.
Old 07-17-13, 11:54 AM
  #33
benztolex
benztolex's Avatar
Any of you guys know if they compatible with the 06GS? They actually look the same.
Old 07-11-14, 08:11 AM
  #34
crwmlw
crwmlw's Avatar
Do these lights stay on while driving?
Old 06-15-16, 08:44 AM
  #35
hisstojay
hisstojay's Avatar
Originally Posted by ekwlee
Ok, part finally got in and I did it, I hated the non-led footwell lighting, esp because you couldn't see it at night, or barely even see it.
Hardness scale: 2; [1-10 (Easy-Hard)]
Part #: 81080-22040
Amt Needed: 2 of the above part numbers
Cost: Approximately $40
Directions:
1. Order the Parts from your local dealer!
2. Secondly you need to locate the lights underneath the steering column (L) and underneath the glovebox (R). See below
Left:
Right:
3. Let's work on the left side first; Just place your thumb on the light itself and push upwards hard. The light should pop out, and it should look like this...
4. Unplug the light and put one of your lights in....then it should look like this!
5. Reorient the light back to the original position, and push the light back into place (its going to be a hard push)
6. Go to the right side of your car (this part is just a tad bit harder)
7. Locate the light underneath the right side
8. Remove the rubber cover from the light (it is just covering the outside of the light). It just looks like below...
9. On the left corner, of the bottom most covering, pull strongly where the bottom panel and the glovebox panel meets.
10. The panel should come down at that corner, and continue to slide your hands along the edge towards the right of the car until the whole panel comes out.
Right Corner
11. The middle of the panel should look like this...
12. Remove the light and plug in the new light, replace the light in the same place.
13. Make sure when you put the panel back you put the panel ends back into the two holes you see in the back (insert pun in here)
14. Put the rubber cap back on
15. Pau! (All done)
After Pictures
How/where did u get the led replacement. i prefer the led to the yellow factory fitted.....thanks
Old 09-09-16, 06:01 PM
  #36
RookieLEX
RookieLEX's Avatar
Do you have the part number on the IS250/350 foot well lights? (what year IS)
Old 09-10-16, 10:08 PM
  #37
RookieLEX
RookieLEX's Avatar
I am silly. The part number is on the first page 😀
Old 02-12-18, 06:38 PM
  #38
es350chuck
es350chuck's Avatar
Blue led footwell lighting. The image is full powered usually when the doors are open or vehicle is in park. When you drive it's half powered.
Old 04-29-18, 09:50 AM
  #39
lipappy
lipappy's Avatar
I love the look of that. Would you mind sharing where you got the bulbs for those (perhaps a link?) and help me order the same thing? Thanks!
Old 09-09-20, 06:17 AM
  #40
tamermido1
tamermido1's Avatar
Anyone replaced the glove box one?
Old 09-09-20, 08:38 PM
  #41
ellocovg
ellocovg's Avatar
I posted it when I did it, I swapped out both footwells, the glovebox, and the center console. There all the same part I bought them from a Toyota dealer. The glovebox wasn’t bad I was able to pluck out the little box, the center console was allot harder.
Old 09-09-20, 08:41 PM
  #42
ellocovg
ellocovg's Avatar
newer style vs oem 07-09 useless orange bulbs.
Old 01-06-21, 05:07 PM
  #43
socaligs
socaligs's Avatar
how did you replace the center armrest one? Thank you in advance.
Old 01-07-21, 05:12 AM
  #44
ESh
ESh's Avatar
You have to remove the rear center vents and then just pull the armrest LED.
socaligs (01-07-21)
Acrad
GX - 2nd Gen (2010-2023)
08-11-18 04:15 PM
chikken
IS F (2008-2014)
22
03-13-09 10:29 PM
AACstyle
Lighting
14
10-27-08 01:27 PM
Quick Reply: DIY: Lexus ES350 Footwell Lighting
