ES - 5th Gen (2007-2012) Discussion topics related to 2007+ ES350
$90 oil change?
Old 07-24-10, 04:01 AM
P A U L
P A U L's Avatar
Default $90 oil change?
i took my '07 to a pep boys for an oil change and they said it was $90...said that es350 can only use synthetic oil...is this true or should i take it somewhere else, and a better $$$ is available?
Old 07-24-10, 04:07 AM
eman88
eman88's Avatar
Check the owners manual for what Lexus recommends, I have a 2001 GS430 and only use synthetic oil in my car always, and it cost between 70 and 85 bucks for the change. I always check for coupons first..lol
Old 07-24-10, 04:55 AM
jagtoes
jagtoes's Avatar
Ask the dealer. My dealer uses Dino oil on my 2010
Old 07-24-10, 05:01 AM
IS350jet
IS350jet's Avatar
No, your 2007 ES350 does not need synthetic. It came from the factory with conventional oil and that's what Lexus recommends. Synthetic is a personal choice.
Old 07-24-10, 05:31 AM
LexBob2
LexBob2's Avatar
As others have said, Pep Boys is incorrect. Dino is fine, your choice.
$90 from a Pep Boys seems kind of high. The Lexus dealer near me charges $50 for a dino oil & filter change and $89 for synthetic. I alternate between them and an indy shop.
Old 07-24-10, 09:22 AM
miniz
miniz's Avatar
What does pep boys think they are? A dealer? A Lexus dealer will do the same change for less money. They are clearly employing clueless idiots, as most crappy lube chains do, so please do your car a favor and avoid them all. Price out a Toyota dealer. Chances are they will do the sny change for like $75 or a regular change for $45.
Old 07-24-10, 12:31 PM
MadMax96
MadMax96's Avatar
I wouldn't let Pep Boys check my air pressure let alone do an oil change. To me, the point of going to somewhere other than the dealer for an oil change would be to save money - sounds like that isn't quite the case.
At least if you take it to the dealer and have them charge you about $50 for dino oil, you'll at least get a Toyota filter and everytime I've gone they've washed and vacuumed the car.
FWIW - have you seen the monkeys that work at Pep Boys or even any of the quick lube places? Most are careless idiots.
Old 07-24-10, 05:56 PM
SickES350
SickES350's Avatar
for $90 it better be royal purple!
Old 07-25-10, 06:06 AM
pestleman0
pestleman0's Avatar
Incorrect. Always, always, always check your brake fluid reservoir to make sure they didn't put the wrong fluid in it. It will appear as a different color. Quick lube places are notorious for this. Unfortunately, it happened at a Lexus dealership and Toyota. Lexus had the pleasure of spending thousands to replace the entire braking system. I caught it upon inspection at Toyota. They had to bleed the system. It happens more than you think. ALWAYS check.
Old 07-26-10, 03:30 AM
garsarno
garsarno's Avatar
Just had mine done at local garage: $104.72 total:
6 quarts Mobil One oil @ $8.95 per $53.70
Oil Filter $10.95
Fuel Injection Cleaner $3.99
Fuel Drier / Dry gas $2.95
Lube / Labor / Check fluids / check tire air pressure $7.25
Rotate tires $18.95
Disposal fee $1.00
Tax $5.93
Old 07-26-10, 06:16 AM
LexBob2
LexBob2's Avatar
Royal Purple is a brand of oil.
Old 07-26-10, 10:52 AM
racingt
racingt's Avatar
Oil change at my local Toyota dealer, dino oil/filter -$35
Old 07-26-10, 03:22 PM
pestleman0
pestleman0's Avatar
First time was transmission fluid. Second was power steering fluid. It was a royal pain in the butt.
giantdefy
01-30-10 07:13 PM
kt3333
08-28-09 05:24 AM
LexusFan2
14
07-24-08 03:48 PM
moolman
07-19-07 08:13 AM
HowieNJ
Maintenance
10-04-02 08:27 AM
Quick Reply: $90 oil change?
